Finally got myself one of these Smooth hound wireless do-das at this year's Birmingham Show over the weekend after spending too much time playing twister with cables (driving me nuts) over the last few months.
But ... there's a "but" ... and it's to do with overdrives, fuzzes etc. After connecting up the new unit, I got buzzing (flies all green an' buzzing, the torture never stops) with my Seymour Duncan 805 overdrive and Thorpyfx Veteran Germanium. This through a Princeton Reverb and through a THR10 practice amp.
So, reviewed the setup, and took them (805 and Veteran) out of the chain, and lo .... no buzz. What gives?
The setup is unplayable with Smooth hound
AND either/both the 805/Veteran, so can anyone suggest what to do so I can re-integrate the two dirt pedals without the bzzzzzz?
@SmoothHoundUK@thorpyfx@not_the_dj - including you because you mentioned a while back that you suggested that there were some issues between the Smooth hound and vintage fuzzes.
when you place a buffer or a wireless unit (which has a buffer built into it)between the guitar and this pedal then you take away the interactive element that crafts the fuzzes sound. Aside from that they just don’t work well together, depending on the buffer you can end up with effects from a tad of brightness through to whistling, screams etc... now the smoothound can have the virtual able length adjusted so I’d suggest you try this to see if it improves.
pm me if you want to discuss it further.
The only pedal I have a problem with is a Varitone-in-a-box type thing I use occasionally.
The buffer in my Line 6 G10 renders the effect useless, but then it has a set virtual cable length.
It's just one of those things I'm afraid.
Have reintegrated the 805 without bzzzzz, but the Veteran ....
Thanks to all who chipped in above.
Ebay mark7777_1
