Smooth hound - problem resolved
fandangofandango Frets: 2204
edited March 2018 in Guitar
Finally got myself one of these Smooth hound wireless do-das at this year's Birmingham Show over the weekend after spending too much time playing twister with cables (driving me nuts) over the last few months.
But ... there's a "but" ... and it's to do with overdrives, fuzzes etc. After connecting up the new unit, I got buzzing (flies all green an' buzzing, the torture never stops) with my Seymour Duncan 805 overdrive and Thorpyfx Veteran Germanium. This through a Princeton Reverb and through a THR10 practice amp.
So, reviewed the setup, and took them (805 and Veteran) out of the chain, and lo .... no buzz. What gives?
The setup is unplayable with Smooth hound AND either/both the 805/Veteran, so can anyone suggest what to do so I can re-integrate the two dirt pedals without the bzzzzzz?
@SmoothHoundUK
@thorpyfx
@not_the_dj ;- including you because you mentioned a while back that you suggested that there were some issues between the Smooth hound and vintage fuzzes.
  • No idea why, as I do not use these pedals. I have had a Smooth Hound for over a year, and found it has worked well. Why not ring Mr.Smoothound, if I remember right his name is Chris - he's very approachable, and I'm sure would be happy to discuss things with you.
  • ThorpyFXThorpyFX Frets: 6233
    edited February 2018 tFB Trader
    Long story short, the Germanium veteran is a modified version of vintage fuzz. The reason people love this circuit is because your instrument becomes part of the circuit and interacts with it. A pickup is a complex beast with  varying inductance, resistance and capacitance according to how you play.
    when you place a buffer or a wireless unit (which has a buffer built into it)between the guitar and this pedal then you take away the interactive element that crafts the fuzzes sound. Aside from that they just don’t work well together, depending on the buffer you can end up with effects from a tad of brightness through to whistling, screams etc... now the smoothound  can have the virtual  able length adjusted so I’d suggest you try this to see if it improves.
    pm me if you want to discuss it further.
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
  • p90foolp90fool Frets: 31767
    I'm not surprised, they really do rely on a subtle interaction between your guitar and the pedal circuit.
    The only pedal I have a problem with is a Varitone-in-a-box type thing I use occasionally.
    The buffer in my Line 6 G10 renders the effect useless, but then it has a set virtual cable length.
  • I've got this issue, I've gone through it at length on here and with Chris at Smooth Hound, the Wireless is great, but there are certain things it doesn't seem to get along with and my Suhr Rufus is one of them. I'm selling the Rufus reluctantly now as I love using my Smooth Hound for Gigs, the pedal is redundant.
    It's just one of those things I'm afraid.
    Only a Fool Would Say That.
  • I bought a smooth hound a couple of months ago and have used it once at a gig...never had any problems with using my pedals with it and it is a well built unit that does what it says on the tin..but... I didn't like the feeling of being disconnected from my amp and pedal board...weird eh..? so with that said I'll be selling the smooth hound if anyone is interested.
    • “To play a wrong note is insignificant; to play without passion is inexcusable.”
  • pmbombpmbomb Frets: 1169
    Presumably this is a generic wireless side effect rather than Smooth Hound specific?
    Correct
  • fandangofandango Frets: 2204
    Much appreciate the comments so far.
    Have reintegrated the 805 without bzzzzz, but the Veteran ....
    Does the veteran buzz without the smoothound?
    With a little assistance from Thorpyfx, I've resolved the bzzzzz, and now it bzzzes no more.
    Thanks to all who chipped in above.
  • mrkbmrkb Frets: 6963
    What was causing the buzz?
    Karma......
    Ebay mark7777_1
    Not sure, but resetting the patch leads whilst double-checking the pedal sequence, and ensuring separation of power leads from audio leads might have had something to do with it.
    I should add that all the pedals worked and still work properly on their own, with each other and now with the Smooth Hound.
