Sharps and flats in C major
I’m arranging an old Catalan folk song. It’s in C Major, but it also has a flat 5th in there.
My question is a general theory question. When you use an out-of-key note in C Major, is it sharp or flat? In my example, is it called Gb or F#? Or can you just pick whatever you fancy?
  • vizviz Frets: 10708
    edited April 2018
    You can choose, but they do have different nuances.
    If you’re specifically wanting to write in Lydian, replacing the perfect 4th with an augmented 4th (like The Simpsons - though that’s not strictly speaking Lydian) then you’re sharpening the 4th note to an F# (indeed you could write the whole piece with a G major key signature if you wanted)
    If you’re linking the perfect 5th to the perfect 4th with a chromatic, bluesy feel, particularly downwards, then it’s more likely to be a flat 5 - ie a Gb.
  • The song uses the it as a passing note to add tension, played twice after the G. That would make it a Gb then, right?
    Prob but let’s have a listen :)
  • ArchtopDaveArchtopDave Frets: 1371
    Given that the C Major Scale itself hasn't any sharps, or flats, then it probably doesn't matter which you choose provided you consistently use either a sharp, or a flat, and don't mix them. In general terms, you normally use a sharp to alter notes if the underlying scale is one with sharps in it, and flats where the scale contains flats.
    One thing I didn't mention above is  - are there any particular conventions in Catalan music to help you decide which accidental to use?
  • One thing I didn't mention above is  - are there any particular conventions in Catalan music to help you decide which accidental to use?
    That I don’t know — I’m not a native. But that’s a good point. I shall ask.
  • HAL9000HAL9000 Frets: 9702
    That's probably what I'd do. If the preceding note was a G then I'd go with Gb. If the preceding note was F then I'd go with F#. No reason except that it helps show where you're headed from where you are now.
    @HAL9000 that seems quite reasonable, in the absence of any other conventions
