If you’re specifically wanting to write in Lydian, replacing the perfect 4th with an augmented 4th (like The Simpsons - though that’s not strictly speaking Lydian) then you’re sharpening the 4th note to an F# (indeed you could write the whole piece with a G major key signature if you wanted)
If you’re linking the perfect 5th to the perfect 4th with a chromatic, bluesy feel, particularly downwards, then it’s more likely to be a flat 5 - ie a Gb.
