To say that this one has me in two minds would be an under-statement.
It's a JJ Special Gold, from 2004, according to the CoA. Is it a JJ Jewel or a JJ Retro model?? I honestly can't work out the difference between those model names.
There's a P90 in the neck (which I presume is a JJ own-design) and a DiMarzio in the bridge position, which is tapped, to give a pretty wide range of sounds.
The main reason I'm selling (apart from Mrs TT's constant counting of my guitars - she's still getting lost once she gets to 30 though), is that I'm about to put a P90 and DiMarzio mini-HB into one of GSPBasses' LP DC Jr type guitars, so I can't see this one getting much playtime.
It's light (7-8lbs), and the neck is straight-and-true neck. It sounds big, big, big, although the coil tap is pretty effective too.
There are 3 tiny marks on it, that only show up when it catches the light the right (or wrong) way. You can't see them in the pics above, but you can see them here (if you look carefully) ...
It's £550 in a gigbag, collected from Suffolk or with a nearby meetup. Add £25 for delivery by Mr U, P or S.
I have a "Certificate of Authenticity" for it, serial# 03281, DoB May 2004, from the Hucke/Muschamp era of JJ Guitars.
