Gibson Custom Shop Les Pauls - pickguard gaps?
RandallFlaggRandallFlagg Frets: 13946
I've noticed that a fair number of the 2019 Custom Shop Les Pauls have small gap between the edge of the pickguard and the fretboard, historically accurate or poor machining tolerances of the pickup cut outs by the plastics manufacturer that Gibson are using this year?
What do you think?
  • bodhibodhi Frets: 1334
    edited May 2019
    I believe the gap between the pickguard and the neck pickup's bottom right corner (or bottom left below) is historically accurate, e.g.
    The reissue pic seems a bit off.
  • LordOxygenLordOxygen Frets: 319
    Buy Les Paul, remove pickguard.
    Problem solved.
    1reaction image LOL 0reaction image Wow! 5reaction image Wisdom
  • teradaterada Frets: 5114
    Original pickguards didn’t fit properly in a variety of different ways. Historic les Paul’s replicate this
  • WhitecatWhitecat Frets: 5434
    Yup. Gaps everywhere are normal - and one wonders how hard they “tried” to replicate this or if it “just happens”...
  • BlaendulaisBlaendulais Frets: 3325
    i suspect if they tried they would fail so it must be chance
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • SnagsSnags Frets: 5396
    It's an expansion gap for when you're playing under hot stage lighting, obviously.
    Ahem.
  • RandallFlaggRandallFlagg Frets: 13946
    edited May 2019
    It's not deliberate, Historic reissue pick guards had no such gaps until recently, I think it's a new run of plastics being manufactured, or new CNC mapping for the pickup routing.
  • DanielsguitarsDanielsguitars Frets: 3297
    They're all over the place some have a gap both sides some don't, i can vouch for a montreux pickguard if you want a nice tight fit, no bloody good for the look of the old ones  ;)
    www.danielsguitars.co.uk
    (formerly customkits)
  • robertyroberty Frets: 10893
    Dust catcher
  • ArchtopDaveArchtopDave Frets: 1371
    It’s either a First World problem, or it’s Gibson’s solution to avoiding that annoying Pickguard rattle, that worries you so much.
  • sawyersawyer Frets: 732
    Is it supposed to replicate shrinkage? The Old plastics were susceptible to such problems I think? For all that money I would prefer it to fit perfect meself
    It's not the gap around the pickup, that's always been there there to some degree or other, it's the gap along the edge of the fingerboard binding, past the neck pickup.
    It came in as part of the 2015 'true historic' plastics I believe.
    I didn't see this gap on 2015 TH's
    Hmmm, I have definitely seen the gap around the bridge pick up from 2015. Perhaps the fretboard gap is more recent.
    Bridge gap on a 2015 easy to spot in this video:
    Gaps around the pickups have been there since 1952, it's the gap next to the fretboard I'm referring to, that bridge pickup gap is easily closed using the pickguard adjuster connected to the body. please read my opening post.
    Apologies for any confusion, I'm talking about these ones which I have seen from 2015 onwards. Bottom two guitars are 2015 true historics.
    Regarding the pickup gaps, yep these have been there since the start, but older reissues didn't have the gaps (at least not intentionally), which is why they were added. There was some discussion about this back in the R8 Peach thread. My personal experience is that pre 2014 my reissues have all been very neat, post 2015 not so.
  • p90foolp90fool Frets: 31632
    Do you people ever listen to yourselves? Get a grip, seriously.
    1reaction image LOL 0reaction image Wow! 14reaction image Wisdom
    mind the gap
