Cab sim + FRFR = sound of mic'd amp as heard by the mics used to capture the cab sim
They are not and will never be the same
Of course modellers are capable of doing pretty well anything and everything a real amp can't do, but does anyone really use them creatively for brand new, never-heard-before sounds?
Er, no.
Really disillusioned with modellers and multi-fx right now!
FRFR is almost impossible to achieve.
A full range speaker, especial one designed for live use will never be flat, and the worse part of the response is always around the crossover frequency which is generally right in the upper mids of your guitar tone, guitarists really notice it. That's why I never bothered with FRFR when I had an AxeFX.
You might think employing a couple of studio monitors would improve things. And it will. But then you run into the problem of room acoustics which further alter the sound. It's ok in a controlled space (sounds great in a studio for example) but a pain when you turn up on stage. For that disable the cab sims and get some guitar speakers on the end of your signal chain.
Full Range Flat Response, Andy
If you play your whole set through a Marshall head and 4x12 cab and love the sound then modelling and FRFR would get you close in terms of sound, but no in terms of feel on stage (on the pub floor).
If you were playing stadiums the difference would be less so because you would be hearing most of your guitar through monitors anyway.
It also allows you to play quieter and still sound good out front.
I'm with you though, still like a valve amp up there with me
Some large touring acts incorporate it for the transport (and therefore cost) benefits more than anything else. Metallica, for example, being one of the tightest bands in the planet
Might want to look up Helen Money and Jo Quail.
