This beastie was a kit build... the kit itself came from Precision Guitar Kits in Canada. Kits generally get a bad rap because of all the crap that's out there, but these things really are a bit special. I don't work for them, but I'm a BIG fan - my first was a 'Junior', which I've not given to one of my kids, and this is the second one... I've recently built a third as well, which is gonna be detailed in another thread...
So... here goes...
How the kit turned up - Eastern maple top over a chambered one-piece mahogany body with quarter-sawn, bound neck.
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 01_zpsqn7j4cla.jpgHide glue was the order of the day...
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 04_zpsgrdfwjdl.jpgThis was with no sanding or shaping the neck/body joint - perfect fit
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 05_zpszeppxk3g.jpgPost-grain filler on the mahogany, but sanded back so that only the pores are filled
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 10_zps8rtkk55j.jpgMeasuring up for the tailpiece...
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 12_zpsntjxlqcf.jpg...and marking for that and the ABR-1 bridge
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 14_zpsf125n6m7.jpgAfter having sprayed the nitro colour coat on the back and sides
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 18_zpsbq4eppan.jpghttp://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 23_zpsqes3afiw.jpgAnd the base colour coat for the top. This is metal-complex alcohol-based dye, so it won't fade like yellow aniline does
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 26_zpssq9nc99k.jpgI wanted to shoot for something like a cross between Page's #1 and a bourbon-burst... The burst coats were aniline red and a DIY brown, which will fade over time (in fact, it's already started... Removing the poker chip, the contrast is really cool!)
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 34_zps9x5apjpz.jpgThe headstock was sprayed black and had a white decal applied, which was then lacquered... Here it is mid-buffing
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 35_zps09sozcmp.jpgWiring harness. Russian mil-spec paper-in-oil capacitors, CTS pots
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 36_zpstb94manr.jpgAnd the finished article...
http://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 40_zpst6ujlzs8.jpghttp://img.photobucket.com/albums/v336/walkdev/LP Builds/LP 59 Std 38_zpsylonjn3s.jpg
Can I ask the rude question - what was the delivered cost of the kit, incl shipping & duties (etc)?
From one perspective, by the time you've added the hardware and spent the time/money finishing it, you'll have spent the best part of £1000, and that can buy some rather nice guitars.
From another perspective, for <£1000 you've got a stunning guitar that's specced and finished exactly to your own preferences, based on a pretty good quality base, and with the satisfaction of having put it together yourself.
I know which perspective I take
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Hoof glue has an entirely different set of uses - it stays slightly flexible, whereas hide glue is very brittle once set. Hoof glue is also water soluble even when cured. Hide glue is therefore a much better choice for instrument making.
If you don't want to use hide glue, Cascamite is a better choice than Titebond as it cures hard and brittle, and therefore transfers vibration better.
Also, forgot to say, sorry - lovely work there!
Of course, if I was building full time, I might have a completely different opinion of the stuff - the smell alone would do my head in!
the problem is some are convinced they need to remove the neck on their new £9k Gibson to re set with hide glue. I even believe it could sound better afterwards, but thats just as likely the careful refit and setup the guitar gets as it is the hide glue. Obviously hide glue won't do anything for a badly made guitar made with poor materials.... Hide glue alone won't make a guitar resonant.
i like it because it reminds me of watching my grandad fix pianos. That's enough for me to want to use it occasionally, but titebond original has got me through 15 years of guitar building without letting me down
Instagram
All mine thus far have been made with Titebond. The glue is unlikely to be the limiting factor in any instrument I've cobbled together.
I've got two PGK's and they really are excellent. Word of caution to anyone thinking of ordering one, they've recently just tweaked the designs slightly (rumour of pressure from Gibson), they will still be of excellent quality, just make sure you're happy with the changes.
They have sadly also stopped doing the V and X kits too.
I believe the Precision Kits are about the best out there currently and are used by some bigger companies too....Rock n' Roll Relics started out as Precision Kits.
(formerly miserneil)
Thanks, guys... Yes, Dave, they've just changed the line up. I believe the new headstock design is the main change on the Single Cuts - it's more like a Gretsch headstock now, from what I can work out. I think the rest of the guitar is the same - there were enough differences - the shape of the neck joint, the neck angle, the headstock angle, and so on... I think they're fantastic kits - I'm sure I'll be putting another one together before too long!
