http://www.monkeyfx.co.uk/pictures/amp/ampworkings.jpg
http://www.monkeyfx.co.uk/pictures/amp/ampback.jpg
And I made this glorious 25x1 speaker array. It sounds awful like anything you play into it is a resonator.
http://www.monkeyfx.co.uk/pictures/amp/array.jpg
Also this cab which was much more successful, but now just takes up floor space so will be smashed up and scrapped in the next couple of weeks.
http://www.monkeyfx.co.uk/pictures/amp/cab1.jpg
Amp maker - champ kit:
Amp:
In the cab:
Amp maker - 18 Watt Marshall kit
Amp in the head:
I've got a Triode 2204 which I'm planning to get to this year and an Egnater 50 watt kit on the way soon too - now to find the time to do them!!!
My band, Red For Dissent
If that sounds of interest you can email Bruce and see if he's taking orders for the second run, his email address is in this thread on the MTS forum:
http://mtsforum.grailtone.com/viewtopic.php?t=21271
This is one of the actual amps for sale in another thread on rig talk:
http://www.rig-talk.com/forum/viewtopic.php?f=6&t=168898
Also the amp maker kits are a great sarting point - there very easy to follow and if you get stuck his support is great!
I've built 20 or 30 different effects pedals as well, prior to trying the amp builds. All my builds have been for me to use, though I am likely to off-load some in the coming months in order to create some space in my spare room!
So, here goes:
Ampmaker WF-55 combo - which is a 5F1 Champ "clone" with diode rectification.
http://i.imgur.com/vstkjSX.jpg
http://i.imgur.com/K2zquVD.jpg
http://i.imgur.com/y5uFpx3.jpg
Ampmaker SE-5a head - single end EL84 + 12ax7 5 watt mini marshall with diode rectification and master volume
http://i.imgur.com/ERw9PEf.jpg
http://i.imgur.com/mo0eVH6.jpg
http://i.imgur.com/32dTjW6.jpg
5E3 Clone combo - from a Weber VST kit. Now with a TAD output transformer, Jensen P12Q speaker and Variable Voltage Regulation (VVR), which allows the amp to be played at bedroom volumes.
http://i.imgur.com/PQ0KzbC.jpg
http://i.imgur.com/4tyOq5s.jpg
http://i.imgur.com/ViaLeEn.jpg
18 watt TMB combo - based on the Ceriatone schematic, but with Ampmaker transformers, valve rectification and fitted with VVR
http://i.imgur.com/H1uxaZF.jpg
http://i.imgur.com/bKX8p5n.jpg
http://i.imgur.com/jfLMzBr.jpg
http://i.imgur.com/zSHaMAI.jpg
http://i.imgur.com/MoApTJF.jpg
And finally, an Ampmaker P1800 - 18 watt head marshall type, from the ampmaker kit, and which has VVR as standard.
http://i.imgur.com/y5bY2DO.jpg
http://i.imgur.com/i3aPQva.jpg
http://i.imgur.com/puesiOD.jpg
My homemade JTM45 clone, in a compact cab and running 2 6L6's currently, with a matching vertical 2x12 cab
Trading feedback: Previous (+18) and Current
That cab looks fab! I'd have it, if I had the room. I'm actually downsizing a touch at the moment and the girlfriend is getting the bandit as a bass amp... I think she'd be miffed if I hooked myself up to a 2x10...
Lovely work though. Seems criminal to smash it up
Ceriatone OTS kit.
@hywelg did you do those kits your self - that OTS one look like it was a serious amount of work?
Still got the amp, though now it has a new PT as the Ceriatone failed.
