Headstock clip on pickup thing for use with an iOS tuner app?
LewyLewy Frets: 4226
I really love the Peterson iOS app - I actually prefer using it to my Strobclip and would like to be able to use it live.
Peterson do a clip called the Pitchgrabber Mobile which clips onto the headstock like a clip on tuner and then plugs into your iPhone but they seem pretty unavailable in the UK and quite expensive. Anyone know of anything similar and more readily available?
Thanks!
  • TimmyOTimmyO Frets: 7437
    I'm almost certain I saw such a thing on Amazon the other day when I was looking for a clip-on tuner to recommend to a friend.
    Red ones are better.
  • LewyLewy Frets: 4226
    Hmm...I've seen ones on there to plug into a tuner (i.e. With a 1/4 plug on the end) but not to plug into a smart phone...
  • AlnicoAlnico Frets: 4616
    I am pretty sure that what you want is called a transducer clip and is often used for Piezo pickups.
    HERE is one for a (P) 'Uke' that uses a 6.3mm jack and you just need to get that swapped to a decent quality 3.5mm jack and it *should* work.
    £4.99 isn't much a risk to take but i reckon that will do it. Surely it just picks up vibration?
    @ICBM ?
    What does NASA (Northern Amplifier Salvation Agency) think about this?
    You may well be right - but I suspect Amazon sell another doohickey to achieve the conversion
    Thanks - a fiver is probably worth a punt versus £20 plus for the Peterson equivalent. Although the Peterson plug isn't a simple mono one and I'm not sure why....
    http://www.petersontuners.com/products/pitchgrabber/#PhotoSwipe1475088128338
    A good question...
  • thermionicthermionic Frets: 9649
    edited September 2016
    That's a standard 4-pole 3.5mm jack that your iPhone headphones (which also have a microphone) use, from the tip to the base it's L/R/ground/mic.
    The transducer merely supplies an audio signal to the tuner app, so only the ground and mic terminals are connected.
    Thanks!
  • Hi Lewy - Thomann have the pitchgrabber but it's £24 inc postage.
