You need to work it out for yourself though because it is a thinking process.
You can't possibly learn all the arpeggios in all positions without having a system- and that system is 'drop chords'.
Thanks for the heads up on drop chords @octatonic, I'll give that a look.
I'd recommend working the arpeggios out between frets 1-5 too. That'll then give a pretty exhaustive amount that can then be transferred across the fretboard/other positions etc.
Working it out for yourself and thinking it through is a tougher but more meaningful road. I think you'll be surprised how easy it is to get every key down too, which is vital if you want to develop Jazz improv. Good luck!
abso fa cenlut le
going find for yourself is so much better for you..
the knowledge sticks better and it's better for your ears too..
