The chords don't define whether there's a b6 (A) or a 6th (A#). What's happening in the rest of the song might give a clue.
I suspect adding a b6 might be the way to go if you want to complete the scale, which would make it C#m Aeolian mode, as opposed to adding a straight 6th which would make it C#m Dorian mode. Or avoid the 6th altogether depending on what your ear tells you in the context of the song.
As has been said, the 6 note is absent from the chords; the 'default' key of the song would be c# Aeolian, which would have a natural, minor 6th (A); if you wished to play in c# Dorian, you would raise the 6th to an A#. It's entirely up to you. Raising the 6th sweetens the song up; keeping it natural dampens it down. If you were temporarily to play a 4 chord in the progression, as you climbed up from the E to the g#, that would define the mode - if you played an f# minor - a iv chord - you'd be in c# aeolian. If you played an F# major IV chord, you'd be in c# dorian. Try both and see which sounds most right to you.
Because the progression is consistently diatonic you can noodle away in c# aeolian (or dorian) throughout. If you are interested in knowing the actual scales for each chord like Dave suggested, it'd be:
c#m: c# aeolian (or dorian)
E: E ionian (or lydian)
g#m: g# phrygian (or aeolian)
B: B mixolydian (or ionian)
Finally it's worth mentioning that the minor pentatonic is 'amodal' as it contains no 6th (or 2nd) - hence its universal applicability and appeal - so c# minor penta would fit both concepts, but would be quite boring after a bit.
Whilst there is a IV chord in the pre-chorus I don't think it's enough to determine being in B major (let's disregard the fact it's tuned a semitone down). In the same section it goes i v VI VII leading to the chorus which is in E - I iii IV V (or III v VI VII if still thinking C#m). That A chord has a bigger effect on making it Aeolian... for my ear at least.
I agree that taken in isolation the verse could be seen as Dorian or Aeolian, But in context of the bigger picture I think Aeolian fits better. All the parts are in C# Aeolian.
So for me, it's C#minor/pentatonic.
yep, what I'm trying to say is that either c# dorian or c# aeolian is absolutely fine - but if he wants to stay in one scale throughout, he'll struggle with c# aeolian because of that A# in the F# chord. Of course he can play different scales in sifferent sections - nothing wrong with that either. Or adopt an approach not based on scales at all.
I confess I have no idea what you mean about B major. And c# minor pentatonic is a subset of both c# aeolian AND c# dorian, so I'm not really sure what you mean - probably because I'm just not following you properly!
I'm only referring to B major as the parent key of C# Dorian, I should've made that clearer.
Personally I think he'll struggle more hearing Dorian (although I could be paying him a disservice here!) as his ear is in all probability used to Aeolian as that is what the guys play on the record. They don't play an A# in any of the lead work, they are A naturals.
