I fancy an analogue synth.
Thinking about a full size MS20, a Doepfer A100 mini modular or a couple of Moog Mother 32's
Budget circa £800-1200.
Any comments or suggestions? I don't have a particular sound in mind, I just fancy a bit of old school knob twiddling and patching.
«134
  • StrangefanStrangefan Frets: 5844
    Do t be tempted with anything too old, (I def recommend new or nearly new) keeping old systems that workable and usable is a constant battle :/
    edited May 2017
    IPAD - n lots of these ?  https://www.moogmusic.com/products/Apps
    decent keyboard / controller  n some midi mapping - tweak away ?
  • StuckfastStuckfast Frets: 2416
    I have an original MS20 that has always worked perfectly and never even needs tuning or calibrating. My SH-101 was like that too, though I never much liked it as a synth.
    On the other hand my Polivoks needs to be left on for ten minutes before it even thinks about making a note with a pitch, and even then has to be calibrated every time you use it. Don't think I've ever had an old synth actually break on me though.
  • goldtopgoldtop Frets: 6158
    Sadly, the #1 sensible suggestion is to be a bit patient and wait for the Behringer Minimoog knock-off to arrive (around £450, I think).
    That said, the Minimoog architecture is (relatively) limited, and you can cover more territory with the Xenophone Hypersynth, MFB Dominion, etc. Bass station II or Minibrute are simpler, but decent, as is the new Monologue from Korg (which seems more 'musical' than the MS-20, which I found better for making noises, FX and perc sounds.)
    Left-field modern-but-vintage choice is an Oberheim SEM with any MIDI controller keyboard.
  • GavRichListGavRichList Frets: 7164
    Or one of the Matrix series? - absolutely love my 1000.
    Don't be mean - OP wanted knob-twiddling. ;)
    Haha, fair enough. The sounds though, oh the sounds.
    I spent hours watching videos on that, bought one and haven't touched it.  :#
  • FunkfingersFunkfingers Frets: 14456
    Roland Juno 60 or a Juno 106 that has undergone a VCF/VCA chip service by a reputable specialist repairer.
  • DodgeDodge Frets: 1445
    Lots of good suggestions, some one which aren't matching my requirement for patching, but keep them coming.
    Thanks all.
    edited May 2017
    https://www.moogmusic.com/products/apps/model-15-app  ?   has cable patching emulation :-)
    Ta. Not quite the real thing, and I don't have anything Apple in my house.
    EMS VCS-3 mk II
    I wouldn't hold your breath. They showed a prototype at Superbooth, but I don't think they have even confirmed that it is going to be an actual product yet, let alone when, or how much. It's very much down to the whim of Uli Behringer.
    Personally I can't be doing with Eurorack stuff, it's all too fiddly. Plus if I was spending that much on a synth, I'd want a polysynth/
    Uli would have too much egg on his face if he abandoned the Minimoog clone now. He claimed it's just $200 of parts, asked how Moog could justify the D's pricetag. He is going to do the right thing to give us the same tone for five hundred bucks. After Superbooth he claimed that the developers are just tweaking it now.
    You are right that the form factor makes it look very fiddly to use compared to a Model D.
    Model D is not modular. How about one of these babies? https://www.moogmusic.com/products/minimoog-voyagers/minimoog-voyager-xl
  • MossMoss Frets: 2409
    You're not doing it right until you get one of these
    https://www.moogmusic.com/products/modulars/emerson-moog-modular-system
    Stop crying, start buying
    True, but ISTR that the Behringer clone has some patching for eurorack integration? If the OP wants patching weirdness, isn't the Make Noise O Coast the obvious choice? More patch than twiddle.
  • blobbblobb Frets: 2966
    Seeing as no one has said it yet - ProOne.
    As hands on as it gets
    Not overly complex - 2 OSC, filter, Envelope, basic sequencer
    Patching is limited but limited to stuff you will use and understand what is going on.
    Sounds like nothing else.
    On budget (!)
    Just a suggestion.
    Feelin' Reelin' & Squeelin'
