Acrylic tortoiseshell - just say no !!!!!!
F*cking stuff is soooooo brittle - really difficult to cut/drill.
Manage to get 2mm pickguard nearly right 2nd go, then when I tried to drill it ..... SHATTER !!!!!!! :p
On the advice of Rothko & Frost trying again with Acetate, much more forgiving apparently.
Expensive lessons at £24.99 + P&P a go ! :/
Feedback
  • octatonicoctatonic Frets: 33806
    What was your precise technique for drilling?
    Did you tape it off?
    Or use a wooden block to drill through?
    I supported it on my workmate and had the spot over a hole (to be drilled through) - still had backing on both sides.
    Drill barely engaged before it shattered ....
    Feedback
    edited May 2017
    Ok, next time try using a guide block.
    I use offcuts of ply wood or mdf.
    This is where a pillar drill comes into its own though- because you can clamp everything down.
    Were you using a HSS or brad point bit?
    edited May 2017
    HSS wood
    My jig-saw was creating small chips, but when the supporting part got thin (ie. when I got close to an edge) - that wanted to shatter too and did - but I just got lucky with the outline I think. Conversely I had to make an indent for the floating pickup - that was a doddle with the Dremmel and a grinding stone - perfect !
    2mm Acetate/Cellulose is bendier so should be more tolerant.
    Feedback
    Ah ok- did you drill a pilot hole first?
    Reason I ask is it is useful to drill a pilot hole for acrylic if using HSS bits.
    Helps if you works slowly with acrylic too- once a bit grabs that is it.
    You can get special plexiglass drill bits which eliminate the need for a pilot hole.
    I've always used brad point bits and a guide block and never had a problem.
    Ta. See how I get on with an acetate one.
    I've got a spare laminate sheet (4 ply) tortoise, then white/black/white - not sure what it is made of tbh - might experiment a bit more over the weekend with metal/wood jig-saw blades, and drill bits & blocks
    Feedback
    Practice on the ruined piece first. :)
  • NomadNomad Frets: 549
    In general, for plastics, use very sharp cutters - good quality and as good as brand new, preferably reserved for plastics (or at least soft materials - don't use drill bits that are also used on metals). Relatively slow rotation speed and feed rate. Let the sharpness do the work - the rotation speed and feed rate should be such that thin slivers of the stuff is removed with no effort.
    And, as mentioned, put a sacrificial support block/sheet underneath it.
    Nomad
  • AlegreeAlegree Frets: 665
    Blimey where are you buying them from at that price? I sell them at nearly half that price.
    Rothko & Frost (plus P&P)
    Feedback
  • GSPBASSESGSPBASSES Frets: 2351
    When drilling any sort of plastic particularly ones that are exceedingly hard I always run the drill backwards might sound a bit odd but it works doesn't crack the plastic or shatter acrylics. I also run the drill backwards when drilling new paintwork, 2K or polyester, it never  chips or cracks.
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
