Moog MF Delay
RicRic Frets: 0
  • BintyTwanger77BintyTwanger77 Frets: 2219
    +9V, 25mA current draw at most.
  • RicRic Frets: 0
    Thanks Binty, is that a regular power supply like for a Boss pedal, or Boss daisy chain please?
    9volt centre negative (Boss style): bog standard pedal power.
    My favourite pedal.
  • TeetonetalTeetonetal Frets: 7802
    Centre negative 9v boss style.
  • RicRic Frets: 0
    Thanks guys, music to my ears ;) Eric, do you use an expression pedal with the Moog MF Delay please?
    Yeh.
    You can do feedback or delay time, the only problem is it's an internal switch so once the delay is on my pedalboard I can't change between them. I use the Moog ep3 which comes with the TRS cable you need to connect it.
    https://imgur.com/a/zA2Mj
    My pedalboard an iteration ago but the MF Delay and EP3 expression pedal haven't gone. My delay is all black, the one in your picture is black and silver because they changed the look of the range to that although, as far as I know, everything else stayed the same.
  • RicRic Frets: 0
    Yeh.
    Thanks. Never possessed a TRS cable, was told they can do weirdly good things for mixers and effects :) It'd be the delay I'm after, hopefully that will be default-set when the Moog shows up.
