SOLD: AC30 CC2X
NamaquaNamaqua Frets: 62
edited June 2017 in Amps £
Trying a trade now on this AC30CC2X with celestion blue speakers
This AC30 is the CC2X with the sought after Blue Alnico Celestion’s.
It is the top of the range Custom Classic model. Superb sound with blendable Normal and Top Boost channels. Normal channel has the Brilliance switch on it. Foot switchable Tremolo and spring Reverb tank. Comes with brand new RoqSolid cover.
This has the most accurate Beatle tone since the 30/6 and TB originals.
Blue Alnico speakers and solid Birch cabinet.
Master volume so you can dirty it up without it being on full blast. Beautiful sounding amp.
Recent services and retubes by Peter Hall and Henk Phillipsen.
Review here:  https://www.vintageguitar.com/3398/vox-ac30cc2x/
  • 30-watt head based on VOX AC30CC2X Hand Wired amp.
  • All valve two channel Class A combo with valve rectification.
  • Classic tone from two 12" Celestion Alnico Blue speakers.
  • Two inputs - Top Boost and Normal.
  • Custom/normal EQ switch on Top Boost channel.
  • Normal channel with Brilliant switch.
  • Input Link Switch for blending Normal and Top Boost channels.
  • Front Panel Controls: Volume, Brilliance Switch, Top Boost Volume, Treble, EQ Standard/Custom Switch, Bass
  • Reverb Controls: Tone, Mix, Dwell Switch.
  • Tremolo Speed and Depth.
  • Tone Cut.
  • Master Volume.
  • Standby Switch.
  • Rear panel controls: Loudspeaker output jack x 2 (Extension & External).
  • Output Impedance Select (8 or 16 Ohm) on speaker jacks.
  • Output Cathode Bias (82 "Warm" or 50 "Hot").
  • Smoothing Filter Values (22uF "Vintage" or 44uF "Modern").
  • True bypass variable-level effects FX loop (Send, Return and Bypass Switch).
  • Footswitch Jack (Tremolo and Reverb).
  • Two button footswitch included, toggles tremolo and reverb effects.
  • Spring reverb.
  • Vintage-style transformers.
  • Fully variable tremolo.
  • True bypass variable level effects loop.
  • Baltic birch ply cabinet.
  • Vintage L-shaped chassis.
  • Dimensions: 540x705x265mm.
  • Weight: 32 kgs/70 lbs.
Prefer collection but would ship if you want to organise courier and risk it!
I travel around the country gigging so likely to be able to meet in some places.
I've had that one ages darling
  • TravisthedogTravisthedog Frets: 1845
    Any trades?
  • NamaquaNamaqua Frets: 62
    Nothing I need right now so cash only I'm afraid @Travisthedog ;
    bump
    Bumpy bump
    edited April 2017
    Reduced bump
  • AlexHunterAlexHunter Frets: 422
    I bought one of these from Neville Marten years ago, running a fuzz and/or treble boost into it was probably the best live sound I've ever had. Good luck with the sale.
    Still here?! Whaaaaa . .
    It's got nothing to do with Vorsprung durch technique, you know?
    Sunday
    bump
    ac30 bump
    Beatle bump
    Bank Holiday bump with price drop
    Final price drop
  • Colms2005Colms2005 Frets: 18
    PM'd you
    replied
    SFS
    I can't believe this is still here but it is
    Bump
    Let's try a trade now. Amps, Guitars
    Bump
