Now you're talking.
Oh and good luck with the test.
Warm it up, give it a few nice blips of the throttle, or better yet give it a proper run out. See if it has changed at all.
However, to calm my paranoia - assuming tomorrow's examination doesn't throw up any red flags - I'll probably stick a bottle of K-Seal in the boot to get me out of the crap should it go.
I wouldn't trust anything that's posted on forums, there's some proper numpties around.
If the car hasn't been run for a while water (which, as has been pointed out is a byproduct of combustion) collects in the exhaust and will escape as steam.
Ditto a little white/cream gunge around the oil filler cap (especially in winter) can be totally benign for the same reasons.
Just drive it and don't worry about the horror stories on the K-series. Its a weak point, but they don't just fail randomly or just because it hasn't been driven for a while.
Still, not going to worry about it. Having a K-Seal bottle handy means I can probably get out of the shit anyway (if it does go and I'm miles from home), which was my main concern.
If I was you I'd just get some "tow you home" breakdown cover and not worry about it.
I'm struggling to understand the comment about them getting sold as they are "about to fail" - if the cooling system is working 100%, then what notice would an owner have that the head gasket is about to go? Yes the K-series has a weakness because of the long head bolts and the movement that can happen - especially on engines that have been allowed to operate too hot. But I can't see how someone can offload a car just before the gasket fails unless there is an underlying fault.
The trouble with "magic potions" you pour into the cooling system is they can block up the cooling system. Flushing them out doesn't always shift them - I fixed a chap's Imp where 10 years earlier some rad weld or similar guff had been poured into the rad to mask some problems. I ended up having to replace the radiator *AND* strip the head/block to remove the congealed cack that had built up.
Just drive it - keep an eye on the temperature but I think you are worrying too much! :-) And don't believe *everything* you read on forums ;-)
The older magic potions like Radweld definitely had that problem, but K-Seal is somewhat different in that it won't fill any hole larger than 0.635mm - the test is ASTM D3147, apparently, which anything fails if it can't pass completely through a 0.85mm mesh with no residue.
It's still just a temporary fix (not as permanent as the marketing guff says it is), but a lot of people have used it to great effect on these engines.
EDIT: In any case, the fact that AA mechanics carry K-Seal everywhere gives me a little confidence; if using it gums up engines, they'd be getting sued left, right and centre
No idea if he knew what he was talking about or not.
Yeah, I've seen *a lot* of blocked heater matrixes from Radweld. I've also seen blocked coolant pipes and thermostats*. The worst was a destroyed water pump** (the impellor was totally fucked).
It a last option thing, and only if you're right in the shit.
Same for the tyre inflator foam canisters.
*Peugeot
**VW
We drove it for a good half hour, no white vapour in the exhaust, so I think we're good He did suggest that replacing the water pump might be a good idea at some point, preferably with an upgrade (ie more solid valve and metal impellor); he's seen a lot of K-series engines, and in his experience that's usually the component where a fault leads to gasket problems.
Once on the road, reasses.......
Oh, and good luck with the test!
