ALL GONE: Duncan, DiMarzio, EMG HZ humbuckers
FunkfingersFunkfingers Frets: 14496
edited March 2018 in Parts £
http://i.imgur.com/Hxpr8p3.jpg?1
Clockwise from top left.
WITHDRAWN - Seymour Duncan SH-4 JB, cream/black, wound by Maricela Juarez (JBJ sticker), full length height adjustment screw lugs, naturally aged on one of HarrySeven's old MIJ Charvels, 250mm of four-con + shield output cable. £60.
SOLD - DiMarzio DP155 Tone Zone, blue, Gibson pole spacing, naturally aged, 250mm of four-con + shield output cable, £35.
SOLD - EMG HZ H4 high output passive humbucker, black, 350mm of four-con + shield output cable BUT the block connector means that some of that length stays under the pickup, £25.
WITHDRAWN - Seymour Duncan SH-4 JB, OEM, factory chrome cover. Gibson pole spacing. Short adjustment screw lugs. Taken from Hamer XT Sunburst. 280mm of four-con + shield output cable, £50.
Expect P&P to be £4 per pickup. Less for multiple purchases.
Exchange offers considered. If you do not see anything that you like here, ask for what you want. I might have one stashed away somewhere.
  • HarrySevenHarrySeven Frets: 8031
    "...naturally aged on one of HarrySeven's old MIJ Charvels, 250mm of four-con + shield output cable. £60".
    Well...I would have thought that the HarrySeven provenance would add at least...half a groat to it's value!
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • prowlaprowla Frets: 4931
    Well, that comment was worth half a groan!
  • I'd like the EMG if poss.
  • FunkfingersFunkfingers Frets: 14496
    PM reply sent.
  • still got the blue one?? tempted..
    My trading feedback
    Yes.
    Just to reiterate. The polepiece spacing, centre to centre, is 48mm. This will align with strings passing over a Gibson style bridge. It will not align perfectly with the string spacing of a fulcrum vibrato bridge.
    DiMarzio intended the DP155 Tone Zone for use in the bridge/Treble position. Obviously, there is no law that prevents you from installing it as a neck or centre pickup.
    I cannot recall the official DiMarzio name for the blue bobbin colour.
  • yuri_1973yuri_1973 Frets: 101
    hi there, I'll get the blue DP155. please PM me your paypal address pls
    PM sent.
    Both Duncan JB humbuckers withdrawn for use in project guitars.
