http://www.godinguitars.com/johnmclaughlin_07.htm
http://photos.imageevent.com/wiley/jetsam/large/FarSide.jpg
Really, don't worry about it… loads of people have been using DI'd sounds since before there were even decent modellers, and sounded OK. If you're using in-ears as well then the amp is really redundant, to be honest.
Cheapest thing you are going to get that sounds the biz is an Amplifire
It'll either be a line out from the FX to the desk with no amp or a DI'd signal / Mic'd up signal to the desk. Cheap mic or cheap DI too!
Fair enough.
Zoom G3 is beans and sounds alright
There are some cheap solutions, I could build a DI speaker simm for around £30 but's still more than a mic ... which can also be used for other stuff
There me are plenty of cheap solutions for a decent sound via di if you just want to add onto your setup rather than change it.
I'd have a look at either a hk red box type di with speaker sim built in or a tech21 character pedal (or the cheap joyo copies) or the new mooer amp in a box pedals. A red box might be the easiest add on imo.
The line output is better if you go via a Red Box.
