The clean will remain pretty clean until its really wound up, but the magic is really on the drive sounds. Very classy sounding amplifier.
Clean will start to crunch a bit if you are very loud as a band. The real special bit is the foot switch as the extra switch and clean boost are available.
This one ended my amp search.
http://i1270.photobucket.com/albums/jj611/Patrick_Redford/20160701_1842511_zpsdivtcvsa.jpg
What speaker are you using @Teetonetal ? V30 seems to be the favourite with this amp
At home I had it hooked up to a wgs copy of the vintage 30 which I prefer over the celestion one. Not so harsh.
I suspect a celestion V would also sound good but mine is in use elsewhere.
There's a s/h one of these over in Sheffield at Richtone - http://www.richtonemusic.co.uk/products/brunetti_pleximan_head_w_bag_2nd_hand-yother57373.asp
that's a lot of amp for £650!
thanks for the heads up
I'm tempted.
My band, Red For Dissent
I do still fancy a Pleximan, am keeping an eye out for one
