Correct wire for a mid-60s Gibson humbucker?
goldtopgoldtop Frets: 6158
I can find a lot of info about PAFs and early PAT-sticker humbuckers, but not much on slightly later pickups. So wondering if any of you vintage savvy chaps can tell me what sort of wire is correct for a mid-to-late 1960s Gibson humbucker with:
1) PAT-sticker on the underside
2) T-top bobbins
3) chrome covers
Braided outer with a single conductor wire, I think. But what colour/type of insulation?
TIA
  • ICBMICBM Frets: 72418
    2) T-top bobbins
    3) chrome covers
    TIA
    Black waxed cotton.
  • SteveRobinsonSteveRobinson Frets: 7038
    I've just rewired a '64 ES-345 and the insulation was a black rubbery material which had perished and was crumbling.
    I had to remove it all and replace with cloth insulated stuff.
    Sorry I should really do more than skim read posts. The guitar wiring was rubber insulation, the pickups themselves used cloth insulation. Sorry for the confusion.
  • goldtopgoldtop Frets: 6158
    Thanks guys. This helps me decide if/how to restore.
    As far as I can remember, Gibson have never used anything else for single-conductor cable on the pickups.
    If you do buy some, make sure it's cotton and not synthetic (not sure what exact type they use) cloth - not for any snobbery reasons but because the cotton won't melt no matter how much you heat it, which matters when you're soldering it to the back of a volume pot.
    I know that rubber stuff SteveRobinson is talking about, it's a nightmare - it's usually fine as long as it's left undisturbed, but if you need to repair the loom then I agree it can be better just to replace the whole lot rather than try to troubleshoot it.
