I hope it's a nitro safe stand.
This damage is pretty unsightly, but then again so again are all the other variations of nitro damage that one sees, from the finish picking up colour through to it crazing and cracking or even falling off in flakes. Of course, in the crazy logic of the guitar world much of this damage is viewed as actually been desirable or perhaps, as someone put it in this thread, 'kind of cute in a Gibsonny way'!
I know that if a nitro-finished guitar ever came into my possession I would never store it on or in anything that I hadn't received 100% assurance was safe for nitro finishes.
People often complain about Gibson's often shoddy build quality and quality control, but to my mind they should be equally aggrieved about all the design faults that have persisted to this day, from the easy-snap headstock design through to the poor string angles between the nut and tuners - and the continued use of damage-susceptible finishes is just another 'feature' to add to the list.
To be fair what drives me even more nuts is the way those who build 'LP style' guitars insist on faithfully copying all the 'traditional' failings of Gibson's designs. If only a company like FGN or Tokai would build a top-quality 'LP style' guitar with improved neck strength, straight-pull tuners, better ergonomics and so on.
I can't think of another area where 'tradition' has such a sway over reason. For example, I can't imagine that car manufacturers today, if they were trying to sell a vehicle that harked back to look of all those pretty Italian sports cars of the 60's and 70's, would find that such cars could only be sold if, in the name on originality, they also continued to rot before your eyes and had electrics that regularly went up in smoke!
The cure is to play the damn thing once in a while.
I was sold a case recommended for 'Gibson Guitars' http://www.flightcasewarehouse.co.uk/industry/index.asp?section=gibson-guitar-cases-3959 ALL Gibson guitars have nitro finish.... I mean come on ...my guitars been damaged...
Regardless of how well known the vagaries of Gibson’s nitro finish is - it’s only well known if you’ve read about it on the net or in a book etc.
This case ‘shouldn’t’ have damaged the guitar but things have conspired against you in this instance. Not least leaving it in the case for so long...
I think you are pissing in the wind in terms of a better response fron FW and the time and energy you are spending on this isn’t worth it. You are just winding yourself up...
Take the refund, get the repair done with the cash and buy a better case.
Did Flightcase Warehouse specifically state in the advert that particular finishes or storage options were not appropriate for this case?
If they did not, and the OP chose to store any guitar that fit in it that got damaged because of the case itself, then they are responsible.
What part of that doesn't make sense?
Having said that, the OP must still prove (via bona-fide independent chemical evidence) that it was the case that damaged his guitar.
That's not in dispute, in fact they're offering him a refund.
What is in dispute is how much sleep it's worth losing over a small, buffable blemish on the back of a cheap guitar. Is it worth a court case? Seriously? Or just a bit of wet and dry and a free guitar case.
Sometimes it's just better for your mental health to move on, rather than fight every tiny grievance.
Hi, Just thought I'd share my bad experience with Flightcase Warehouse - Spider Cases.
I purchased a Hardcase for my Gibson Les Paul from FlightCase Warehouse and the tab (fake leather) on the case inner compartment has caused a reaction to the nitrocellulose finish on my Guitar neck - basically leached a chemical in the tab and melted an area where it was in contact with the guitars neck.
I contacted the company director who refused to aknowledge any problem caused by his case and basically told me to pay for it to be sent in and tested by their 'tech team' - I asked if they would pay for the return cost but they point-blank refused to.
I spoke direct to Gibson Repair and sent them in the photos and here's their response:
Hi,
I think you’re right. I think the damage was caused by the handle on the case pocket. Pretty poor case design! If you make guitar cases you ought to make them out of materials that won’t harm guitar finishes! I would estimate $450 to $600 to repair the damage and I can’t promise the repair won’t be invisible as it’s very difficult to match the surrounding when you have to fill an unfinished ‘hole’ in the middle of the neck. Also difficult because the chemical reaction that occurs leaches The only other option would be to totally refinish the neck and that would be close to twice the expense. If I were you, I’d get in touch with the manufacturer of the case. They should know better and very well may know but count on people not realizing the cause of the problem. I’ve seen this happen with stand manufacturers too and I’ve seen them pony up to pay for the damages, which of course is the right thing to do. Feel free to use this email to provide a potential cost and if they agree to pay I’ll provide a detailed – to the penny quote once we have the guitar in hand.
Thank you,
Gibson Repair & Restoration
I also spoke to many guitar luthiers who agreed that the Flightcase Warehouse Spider case inner tab had caused the damage.
I sent all info over to the company director and again he basically refused any problem was his and that it was the guitars finish that was to blame.
Basically flightcase warehouse refuse to accept any problem and will only look at the case If I pay for return postage which they stated they would not refund and could take a few weeks to inspect.
So in the end I have a badly damaged guitar finish caused directly by the case from flightcase warehouse and they continue to sell their cases as 'Gibson' suitable guitar cases when they are clearly not - BEWARE!
nibs
I normally avoid these threads but this one - if it’s the one I’ve read about before - seems pretty clear.
@nibs there’s a decent summery of the law here: https://www.which.co.uk/consumer-rights/regulation/consumer-rights-act
Pay particular attention to the fitness for purpose bit.
See if you can get a written statement from one or preferably more of the people who’ve examined it and concluded that the tab caused the damage.
Then write a ‘letter of claim’ to the supplier explaining precisely why you are entitled to hold them liable to repair the damage. Identify the cost and give them a reasonable time to consider and respond - 21 or 28 days would seem sensible.
If they continue to refuse to play ball, go here and follow the instructions: https://www.gov.uk/make-court-claim-for-money
