NGD jaguar content
wrinkleygitwrinkleygit Frets: 259
edited March 2018 in Guitar
Bought this recently & did a couple of tweaks.
             I couldn't find a use for the strangle switch so this has been converted to a series/parallel switch, vintage style tuners converted to locking tuners & oem bridge converted to roller saddle type which smooths out the trem operation.
                Hung on a strap & strung with 10-46 this is an absolute joy to play & with the ser/par switch option it suits me perfectly, all I can say is if you're showing your age like me then you need to buy one of these.
               For info, the locking tuners ( which I have used on other guitars & work well, you may need to open headstock holes as these use 10mm bushings ) together with the roller bridge which has 6mm post holes & fits straight on the posts of the mim AOM, for the switch conversion you will need a DPDT slide switch, I used Maplin part noFH36P which is a perfect fit you will also need to disconnect claw earth wire from pickup & solder on a separate earth wire. pics below
https://www.dropbox.com/sh/dt2nfuo7zf6k1cl/AAAvaZ8bu7ztvk4eh14Dg9pqa?dl=0
  • SeshSesh Frets: 1847
    Very nice. One day I will jag too.
    Can't sing, can't dance, can handle a guitar a little.
  • Jack_Jack_ Frets: 3175
    Holy wall of text.
  • BrizeBrize Frets: 5629
    Dude, paragraphs!
  • remember how your grandad used to waffle on (gulp)
  • Which MIM - is it a Classic Player, or something else?
  • Grocer_JackGrocer_Jack Frets: 258
    edited February 2018
    Ah - just looked at the pics. It IS a Classic Player - the tuneomatic gives it away. Played one of these when they first came out - it was excellent with a real growl into a cooking amp.
  • robgilmorobgilmo Frets: 3500
    I am so glad that didn't end with ''and that's how we won the war''.
  • Congrats on the new guitar and finally coming round to the Jaguar. A poor man’s strat it very much is not!
