Then you're stuck with whatever speaker is in your cab. If it really works as advertised I think it'll be great
Sounds like it is a kind of hybrid 12" speaker that's a bit of a cross between a PA speaker and traditional guitar cab speaker...
I suspect more cabs will follow from other manufacturers.
Is that what's in the Line 6 unit?
Ebay mark7777_1
Taken from Line6 product description:
What’s the reference speaker used?
Powercab features a custom designed 8Ω, 12" coaxial speaker that uses a guitar-style cone as opposed to a PA-style cone with a 2” high-temperature voice coil loosely based on the Eminence Beta 12CX format. The 1” compression driver is a Celestion CDX 1-1010, which is used only for Flat mode, monitor feeds, and user IR modes; it’s not utilized at all for speaker models.
