Switching to a separate channel live has always been a lottery for me, will my guitar take everyone's heads off with volume or will it totally disappear in the mix?
Although this is the reason I don’t like multi-channel amps which don’t have a single overall master volume/level control... you can’t adjust one channel without having to then adjust the other one. With a single control, the balance between the two should remain the same if you turn up or down.
Bigger gigs through supplied PAs are different obviously, but most pub band sound check are bar-emptying ego trips and I don't tolerate them.
My Redplate CDS2 has a choice of 2 pre-amps - blackface/tweed.
After this, there is a 3 button footswitch which adds boost (mids) and drive (or both).
I havent used an OD pedal since Ive got this.... incredible
