Hello all,
I'm thinking about having a go at stripping the neck on my tele. it's a mim nitro neck, so I suspect it's got a poly undercoat.
I want to strip the lot, fretboard too (maple) and refinish in oil.
Does anybody have any pointers?
The Bigsby was the first successful design of what is now called a
whammy bar or tremolo arm, although vibrato is the technically correct
term for the musical effect it produces. In standard usage, tremolo is a
rapid fluctuation of the volume of a note, while vibrato is a
fluctuation in pitch. The origin of this nonstandard usage of the term
by electric guitarists is attributed to Leo Fender, who also used the
term “vibrato” to refer to what is really a tremolo effect.
Start with 250ish grit then upto 600 once it’s just wood, then 1000 before lacquering. Haven’t tried a fretboard though, seems you need a scraper/blade to get around the frets carefully.
Ebay mark7777_1
The best (quickest, safest) way to strip is using a scraper. A Stanley knife blade works well between frets.
Get most off with your scraper then finish with fine sandpaper, 320 grit.
If it's all nitro and no tough sealer then you can dissolve it off using thinners or MEK but watch the dots don't dissolve too.
I think I might have to man up and go in with the blade
https://www.facebook.com/rendallsrestorations?fref=ts
If I remember I’ll post pics tomorrow
• Youtube - https://www.youtube.com/@Goldeneraguitars
