Going back to an old-fashioned all analogue board after running a Helix for the past 2 years
John_AJohn_A Frets: 3775
Dug out a load of pedals and stuff yesterday that I had fond memories of, 3 hours later I had a pretty inflexible tangle of wires that sounds OKish.  Don't know why I bothered :)
3reaction image LOL 0reaction image Wow! 2reaction image Wisdom
«1345
  • thecolourboxthecolourbox Frets: 9812
    I saw a helix the other day though and it was massive, much bigger than my pedal collection. I appreciate it is good and sounds brilliant but for my space available and use case, pedals still win to be honest
    soundcloud.com/thecolourbox-1
  • John_AJohn_A Frets: 3775
    edited May 2018
    Yes, it is a big lump.  Not bad when that's all you  are taking to gigs, but size was one of the reasons I put a new board together for when/if I fancy using a real amp.  Think a HX effects is on the cards
  • robinbowesrobinbowes Frets: 3046
    "massive" ??
    For sure, it's bigger than 2/3 pedals on a small board, but it's hardly "massive", especially if you remember it's replacing your amp(s) & cab(s) too.
    R.
  • WazmeisterWazmeister Frets: 9571
    I'm trialling the HX and Helix Floor at the moment... the HX is amazingly good :)
  • Winny_PoohWinny_Pooh Frets: 7778
    Wow, two years since the Helix came out!?
  • Musicman20Musicman20 Frets: 2326
    I'd personally try the HX effects, but I found the Helix too much, too large, and I didn't enjoy it as much as I thought I would. At the moment though, I love my individual pedals. I'll never ditch them.
  • EricTheWearyEricTheWeary Frets: 16297
    I had a look at the HX effects at the Birmingham guitar show and it is pretty small.
    I know it's stupid but it wasn't sexy ( although I don't know why a random mess of pedals and cables would be) and buying one seemed to fall into the same category as paying to have the boiler repaired - sensible but ideally you'd have more of a thrill ride for several hundred pounds. But, quite small.
  • flying_pieflying_pie Frets: 1817
    Helix isn't that big when you consider that they are not just replacing pedals but also include a multi pedal and amp channel switcher and back up amp with DI and power supply. If you need all those things then it's a lot smaller than the analogue equivalent.
    I still have pedal GAS, and I don't get particularly excited about my Helix, but it's a superb tool for gigging and makes my life so much easier.
    R.
    Yes, the stuff I cart to a gig has drastically reduced since I got the Helix.  Don't really know why, but felt I needed a 'normal' rig too, forgot how much I hate patch leads!
    Also, if you add up the cost of my very small 'normal rig, pedaltrain, PSU, 5 pedals and a switcher, I could have a HX effects, some change and never look at a patch cable again!  Think I've just sold myself on the idea :)
  • digitalscreamdigitalscream Frets: 26641
    I found the Helix LT a bit big, but then I considered the size of my board and the off-board wah and....it's no more than an inch bigger in each direction.
    Since then, my only GAS has been for the ideal power amp - I now have a Velocity 120 and my old R&R SOLO 1U valve head, which means I'm basically covered for everything.
    Funny thing is, I know the Helix isn't sexy, but it's done everything I've asked of it (including reproducing the clean, rhythm and lead sounds in my head perfectly, which no amp has ever managed). On top of all that, the whole idea of getting a bunch of new pedals every six months or so - for free - has completely blown my mind.
    Can't even remember what pedals I've got left. Might have a Flashback Mini somewhere, dunno. Can't see myself ever going back, except perhaps to put together a backup rig just in case.
    <space for hire>
    edited May 2018
    I've been using a pedal based rig for band writing/rehearsals the past couple of months, leaving my Axe FX 2 at home to do the recording with.
    All it's done is increase my GAS for a second digital unit.  It's so inconvenient switching everything manually, some sounds are taking 3 clicks which there is no way to do smoothly.  Maybe when the used value of the 2 drops further once 3's are more readily available in the UK.
    Also I'm developing an intolerance to cabling.  The less cables the better.
    Gone from a monster board (loads of pedals for one tune), to a few micro pedals (tuner, overdrive, distortion, fuzz, chorus, autowha - and fuzz/autowah are on borrowed time)
    Idea was to use PoD HD 500 for specific tunes with complex FX setup if needed, but as we've not adopted any multiple delay/modulation tunes it's not currently needed at all.  Might migrate to a HELIX LT in due course, but not pressing ......
    Feedback
    "massive" ??
    R.
    But PA or FRFR amps are bigger than the amps I have as well so the combined space they'd take up at home would be huge still.
    I totally get it for some use cases and yes the HX is small (I was considering one when I saw the full size helix) but my board of a drive pedal, fuzz, octave plus Zoom G3 gives me loads of stuff as well but is smaller and i can take out the G3 for when I have less floor space
  • SporkySporky Frets: 28435
    The Helix (full-fat) is smaller than my Pedaltrain, I'm pretty sure. And it does vastly more and sounds at least as good.
  • revsorgrevsorg Frets: 880
    The other day I went on a trip down memory lane and watched this 2014 interview with Jeffrey Kunde talking about his pedalboard.  I can't believe how complicated his setup is. Hard to imagine going on stage and not experience some kind of problem.  The sort of problem you'd never experience with a Helix.
    @revsorg You have to admire someone with the patience to put something like that together, but as you say, when a 'red lead' fails pre-gig you'd really be sweating it!
    All my remaining pedals up for sale, I'm never going back :)
  • sweepysweepy Frets: 4187
    edited May 2018
    That pedalboard needs a BOSS ES8 loop switcher
  • LebarqueLebarque Frets: 3880
    edited May 2018
    No doubt the Helix is convenient and flexible, but it's a compromise on tone compared to good quality analog pedals IMO. Not to mention 'death by digital menus' syndrome. Maybe I'm just old and like a simple pedal with three knobs, so I can focus on playing.
