Had this amp custom made for me a few years back by a fella who used to frequent either here or the old music radar forum, Pete (think it was 'Moon Amps' or something).
It's a point to point hand wired JTM45 with a few additions:
KT66 power tubes.
Copper cap solid state and valve rectifier (switchable).
A JTM45/JMP switch that changes the tone stack somehow to make it more similar to that in a JMP100 (front panel switch).
PPIMV which can be switched out (front panel switch).
2 speaker outputs (switchable 4, 8 and 16 ohms)
Gold plexi faceplate and Marshall knobs, blonde Fender tolex.
Cab dimensions - Length 20.5 inches, Height 8.5 inches, Depth 9 inches.
The only negative is the quality of the cab construction is not best but adequate for the job. The tolex is in great condition though.
It had a white Marshall nameplate on it but this has been removed
£500. £400. Can be collected from near Stockport.
His name is Peter Skelton and he went by New Moon Amps.
I believe he moved to the USA and is starting up a brewery!
That's turret board BTW, not PTP (not inferior, just different)
