People do this for either of the first two reasons you mention. Not sure it achieves your third proposition, a big part of the feel of a 12 fret is due to the corresponding bridge position.
Haven't looked into the acoustics section for a while, so resurrecting a slightly older discussion, but it's not purely the bracing.
I don't know if it's in the current line up, but when I was looking at good acoustics several years ago, I played the slot headstock 12 fret Martin HD28VS, and also the 14 fret HD28V. They both have the vintage style bracing, but they do sound different. I had a 12 fret Furch Dreadnought for a while as well. That had a different tone to the 14 fret version. To me, if you are looking at dreadnoughts, the 12 fret sounds a bit more open, and doesn't have the big (overwhelming??) bottom end that a 14 fret guitar has.
The latest Martin D18s and D28s have gone back to what they call "forward-shifted" bracing - basically pre-war spec. As far as I know, they changed the bracing (on dreadnoughts at least) in the mid 1940s. I'd agree that the tone is better with the "forward-shifted" bracing. To me that makes a bigger difference than scalloping it. An HD28V (forward-shifted and scalloped) sounds a lot better than the older HD28 which was scalloped but post war positioning. I'm not sure what the spec is on the latest HD28.
They changed the D18 a few years ago (2012?). Not sure if it was scalloped, but forward shifted at least.
Hope that helps
