WTB: Replacement pick guard for Squier VM P bass
Hi guys,
Just picked up a Squier VM pbass and the guard that is on it is not fitting correctly.
Does anyone out there have one they are looking to sell or maybe know of a direct drop in?
Thank you
  • FunkfingersFunkfingers Frets: 14496
    How about the black/white/black 'guard from this 2014 Squier VM?
    https://i.imgur.com/fYVm2f8.jpg?1
  • How about the black/white/black 'guard from this 2014 Squier VM?
    Do you know if this the same layout as The none PJ aversion? Mine is the older Olympic white version.
    How much were you looking to sell it for?
    Thank you!
    In what way is the current 'guard not fitting?
    Do you know if this the same layout as the non PJ version?
    In the design sense, the layout is the same.
    The one obvious difference between a PJ version and the regular P is that the 'guard in the my photograph would need the control pot hole nearest the bridge enlarging to accept a jack socket.
    Missing from my Squier 'guard and, probably, yours too, are any pre-drilled holes for a thumb rest or the metal screening plate.
    The white mark next to the E string is the protective plastic  sheet catching the light.
    £15 PPG shipped.
  • Just picked up a Squier VM pbass and the guard that is on it is not fitting correctly.
    £15 PPG shipped.
    PMd
    Replied.
