If he doesn't get on with it like that, it's very easy to convert a right-handed classical (at least, anything apart from a high-end one where the bracing may be different internally) to left-handed - you simply restring it the other way round . Depending on whether the bridge saddle is at all angled you may have to flip that as well, but many aren't.
I would also suggest that if he's at least of average size or bigger for a six-year-old, try him on a 3/4-size not a 1/2-size. The quality difference between budget models of each is enormous, the 1/2-size are not much more than toys, whereas the 3/4s are more like a small proper guitar.
I work for a mail-order company which sells both sizes - if you can afford to spend a tiny bit more there's a big jump in quality above the most basic entry-level models too, for not very much more money.
In fact I've never understood the handing convention, it makes sense to me that the dominant hand should be the fretting hand, if starting over.
The best bet if you can find one is one of the older Fender/Squier Duo-Sonics, with the 22.5" scale - the body is also slimmer than a normal 3/4-size electric. (The current model is a 24" scale though.) The older ones can be identified by having both pickups angled, and only 20 frets (3 dots above the 12th not 4), like this -
https://images.reverb.com/image/upload/s--ebqVwf0d--/a_exif,c_limit,e_unsharp_mask:80,f_auto,fl_progressive,g_south,h_620,q_90,w_620/v1493503056/yrhxnjzumx6h07no8nwe.jpg
They're not actually very expensive, because the very short scale puts most people off.
So next bit is what should I look at? He is very tiny for 6 @ICBM , which is why I thought of a 1/2 size. I have a Yamaha APX 500, which I guess is not hugely bigger than a 3/4 size. I'll give it to him to hold, but I suspect 3/4 may be difficult for him. I'm happy to spend a little more than bottom end, but 6 year olds are fickle Any suggestions for a 3/4 sized classical/acoustic? And 1/2 size if any are worth it?
Cheers all.
I'm OK with waiting, if there not ready then they're not.
If he's very tiny for 6 then a 1/2 might be the only option for a while. They are usually pretty terrible though... my advice from the ones I have to inspect and ship is look for one with a zero fret, they tend to play better than the ones with just a nut, and be prepared to spend a fair bit on a decent set of strings - hard tension classical, which will make it play and stay in tune a lot better than the rubber-band-like ones they come with.
Avoid steel strings at that sort of size, they have the same problems of tuning stability, intonation and cheesegrater action as the 1/2-size electrics do.
The smallest/cheapest steel-string acoustic that's worth having is a Yamaha FG Junior (now called a JR1 I think) which is described as a 3/4, although the scale length is only 21.5" if I remember right, which is shorter than most other 3/4s.
The other disadvantge of a steel-string is that it can't be as successfully converted to left-handed if that becomes necessary...
We also have a Brian Mini May we got off the forum when she wants to plug in and make some noise! But I got that when she was about 2
