Project swimming pool!...
  • WezVWezV Frets: 16725
    is it really ready for buffing and going to check when the paint has only been on a day?
  • poopotpoopot Frets: 9099
    It’s always worked before tbh!...
    I have buffed early before, never that early.   I am surprised you don’t see it sinking in drastically after that.  Sometimes that’s the reason I buff early, but it’s done at a week, not a day.  Everything else waits 4 weeks minimum so it’s harder and more brittle before checking
  • DanielsguitarsDanielsguitars Frets: 3297
    That's what i do Wez
    www.danielsguitars.co.uk
    (formerly customkits)
    Not really buffed... not on a wheel anyway... was flatted back a little just to get shot of some orange peel and then hand polished with a rag I have which is now more Tcut than cloth!!!
    the freezer thing is a bit of an experiment... it’s the first time it’s been empty in 7 years and it’ll prolly be full again by the weekend...
    wont hurt to bung it in overnight!... see if it does work...
    edited August 2018
    So after a night in the freezer we have ended up with this.
    So there you go... you can get Day old nitro to check (providing you use my secret recipe before buffing and freezing )
  • munckeemunckee Frets: 12393
    "providing you use my secret recipe before buffing and freezing"
    the blood of virgins? unicorn tears?
    Looks great chief what a job you've done in such a short amount of time.  I assume missus poopot has paid for the stuff while acting extremely apologetically.
    I showed missus munckee the picture and explained your wife did it, she said "wow you would leave me on the spot if I did that" and I said "yup" and we both stood there in silence for a minute each in deep thought...
    @poopot - I’m not sure Speed Building is a national sport...
    Looking forward to pics of this one when the missus dumps it in tbe bath ;)
    I use this just before sanding, buffing and checking...
    Hahahahahahahaaha!... you owe me a mouthful of coffee for that one!!!!
    She won’t be able to... I will permanently fix this tele to the back of her wardrobe door... to taunt her ever time she goes in there ;)
    Bit more done, nearly back to gigging spec...
    new switch and pots arrived and glued together:
    Mojo 59 relic set back in...
    Gonna have some lunch now, bing some strings on it, give it a quick set up and crack on with some proper work!... video to edit ‘n all that!!!!
    So why do Fender Custom Shop relics cost so much when basically you can do one in 3 hours in your garden?
    CHEATIN' FECKERS!
    edited August 2018
    CHEATIN' FECKERS!
    Don’t know... and tbh thanks to @customkits and the fecking awesome slabboard neck he did me... a fender custom shop won’t even come close to this!...
    Edit**** plus fcs don’t have access to my pot of “green” ;)
    Sarnie eaten... strings on... back in business!...
    this body seems to chime a bit more acoustically than the last one... @customkits has that now so watch out for a “repair” thread at some point...
    Fin.
    what's the weight difference between the 2 bodys
    This one was 2kg... you have the old one, what’s the weight on that?
    About 24 hours by the looks of things!!
    That’s impressive, but why all the feckin “secrets”?  Ain’t nobody willing to give a little back anymore?
    It’s a closely guarded family recipe... a mix of “blue” and a pinch of “yellow”. Turns lacquer hard in minutes!...
  • rsvmarkrsvmark Frets: 1383
    @poopot fine work sir
    An official Foo liked guitarist since 2024
  • Jez6345789Jez6345789 Frets: 1783
    Not really much of a secret formula with rattle cans. can’t exactly vary the mix. i presume it’s just applying all the things that will help.
    So warm dry air rather than heat, good airflow. Making sure the body is at the right temperature
    plus the way it’s finished with minimal sanding and
    Tcut is not the same as flatting out through the grades  and machine buffing.
    still would of been nice to share the technique if it’s that good.
    it looks the part so nice work
