If I got a Baritone Guitar Could I......
SNAKEBITESNAKEBITE Frets: 1075
If I bought a Baritone guitar could I tune it and play it in the same way I would a "conventional" guitar?
    I think the scale length would be too long to comfortably tune it to Standard. I'm sure the strings wouldn't break but there would be a lot of tension.
  • gusman2xgusman2x Frets: 921
    You would tune it to B probably, but yes all your chord shapes and scales work the same. It's just that they're now different chords and scales.
  • WhitecatWhitecat Frets: 5433
    Even if you could, surely it would just sound like a regular guitar with crazy heavy strings?
  • FunkfingersFunkfingers Frets: 14482
    If you can find suitably long sets of tens or elevens, yes.
  • EricTheWearyEricTheWeary Frets: 16297
    edited August 2018
    I was watching a bit of the Chords of Orion bloke and, I think, he plays a baritone but just plays more up the neck. He's not going boing boing boing all the time, the extended range down is there if he needs it.
    Presumably you lose some high notes as well?
    For someone like me who's mostly playing small closed chord shapes and pentatonic scales and doesn't really use open stings I guess it would work, I'd just venture down toward the nut on occasion.
    edited August 2018
    It would probably be best to just tune it to B standard and use a capo on 5th
  • SporkySporky Frets: 28446
    Yes - all other things being equal you lose as many high notes as you gain low notes.
    Which is a clear advantage on both sides. :)
  • DefaultMDefaultM Frets: 7345
    Whats the scale length? 27" is fine in standard. Never tried anything longer.
    Steinberger Transcale.
  • GluedtoMusicGluedtoMusic Frets: 74
    edited August 2018 tFB Trader
    Baritone guitars don't increase the tension by as much as going up a standard string gauge set, so 9s at 27" is less tension than 10s at 25.5".
    I have 27" guitars set up with 9s and they work great.
    Here's the tension comparisons,
    9s @ 25.5"   9s @ 27"   10s @ 25.5"   10s @ 27"   11s @ 25.5"
    e 13.14 lbs   14.730 lbs    16.22 lbs    18.19 lbs    19.63 lbs
    B 11.02 lbs   12.350 lbs    15.39 lbs    17.25 lbs    17.85 lbs
    G 14.68 lbs   16.460 lbs    16.58 lbs    18.58 lbs    18.58 lbs
    D 15.73 lbs   17.630 lbs    18.39 lbs    20.61 lbs    21.12 lbs
    A 15.50 lbs   17.380 lbs    19.04 lbs    21.35 lbs    20.96 lbs
    E 14.37 lbs   16.110 lbs    16.91 lbs    18.96 lbs    18.97 lbs
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
  • SNAKEBITESNAKEBITE Frets: 1075
    Cheers guys.
    I was just contemplating something different, but didn't want to venture into the whole over complication thing.
    Playing normally is taxing enough!
