For sale Digitech 2112SGS valve pre-amp processor unit. This unit has been upgraded to the 2120VGS Artist spec so is identical except the purple front panel.
Comes with the Control 1 footswitch which gives you access to all the presets, individual FX ON/OFF & a continuous controller pedal which gives real-time control of numerous parameters.
This is a 2U rack mount tube preamp with digital effects section. Has dual signal path with solid state & valve distortion, FX loop and can assign every parameter to some kind of control, either footswitch, pedal, or there is a built-in wave generator that you can assign to parameters for automated control.
Excellent condition having only been used at home and never gigged.
NOTE: This is a USA voltage unit but will be shipped with a drop-down UK transformer.
All manuals included.
£190 delivered
FEATURES:
Artist Authored Custom Presets
Dual distortion path routing
Dual Tube Preamp (12AX7)
Full bandwidth effects (20-20kHz)
24-bit signal path, 48-bit internal data path
Up to 8 digital effects at once
Dual S-DISC II ® Processing
Flexible, easy-to-use effect routing
Effects can be repeated in a chain, (e.g. EQ + flange + EQ + pitch shift)
Expanded Delay Times (5.0 Seconds in Full Modules)
Instant module access
Exclusive Dynamic Parameter Control
Programmable Speaker Cabinet Emulator
Chromatic tuner
Full MIDI Implementation
All effects and parameters available for MIDI continuous control
2 Expression Pedal insertion jacks to add external CC pedals for additional assigning options
Fully Programmable Foot Controller
More info here:
