Gonna Buy a GT1000....don't mention the H word...
andyozandyoz Frets: 718
Yep. I've decided.
  • equalsqlequalsql Frets: 6140
    "Aaachhooohelix.." oops sorry about that..had to sneeze ;)
  • StefBStefB Frets: 2355
    Coda had a used minter on for £499 yesterday.  It went within an hour and I'm still gutted I didn't buy it :-(
  • Has anyone tried disabling the amp/cab sims and just used it as a multiFX into a valve amp?
  • andyozandyoz Frets: 718
    Wow
    edited September 2018
    Local player here I respect had a good go at one and seems to have highlighted some keys things that need to be tweaked (depending on how you inent to use it into FRFR or an existing map front-end)...
    I've been through the differences between it and H one and decided GT1000 floats my boat, i.e. I don't need 100 IR's etc. I'll figure out half a dozen thins I want and then leave it the feck alone apart from mucking with FX. The shitty screen doesn't worry me as I'll pnly be looking at patch numbers on it.
    Not on the GT-1000 but I'v run a GT-10 like that for about 10 years and as far as I can tell the cosm technology is basically the same between the units
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • fail..i thought you were talking about the GT-100
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Phew...had me worried there for a minute!
  • PolarityManPolarityMan Frets: 7293
    I would assume that it works at least as well with amp sims disabled though given the older units are great at it
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
