Pickups and Returns
Just about to try some different pickups in one of my guitars. With so much choice its difficult to know what to go for, and Im thinking that once you soldier the pickup cables thats it you can't return them to store, even though it would be a clean job. This could end up being an expensive journey! Is there any online dealer or actual shop that accepts returns of pickups that have been tried, or even accepts swops? Maybe I am simply dreaming here.
Failing that I will just have to wait for ones to come up on here or on eBay.
To give you an idea Im looking for a new HSH with the HB being 50mm spacing. I like the sound of the Suhr SSH+ and SSV set, and perhaps even the Suhr Aldrich in the bridge. Also, would like to try the Di Marzio Humbucker from Hell on the neck. I like the idea that it might sound somewhat like a single coil pickup on the neck.
My Trading Feedback Link is here i_b_tulloch
  • RolandRoland Frets: 8724
    There’s an cheaper way. Check the Classifieds. If you can’t find the pickups you want advertised there then start a WTB thread.
  • Yeah that was always the plan, but some pickups are harder to find. From the threads I read online it seems common in the US that dealers accept pickups back but only to swop for another set, which seems fair. I was just wondering if there is anywhere in the UK that does this.
  • JD50JD50 Frets: 659
    You don't have to solder them, you could use small  connecting boxes whilst you try the pickups out.... that way you can send them back.
  • Thanks JD50, I was wondering about doing something like that. Is there any particularly good type connector blocks I should use? I have loads of the normal electrical connector blocks.
  • AlegreeAlegree Frets: 665
    I accept swaps as long as they're in resalable condition.
    Screw terminals would be a great idea to swap and change as has been previously mentioned.
    Could just leave a little length of your old pickup wire soldered in place, and wrap the new pickup wires around them, bit of electrical tape to secure if its just for a brief test.
  • Yep, pretty good idea again.
  • ICBMICBM Frets: 72442
    If you don't cut the cables short you only need to snip off a very short length to return them to 'as new' condition. I've never found a pickup with a cable so short that makes any difference when fitting it to another guitar.
  • Good point again, thanks.
  • OilCityPickupsOilCityPickups Frets: 10533
    Telecaster Thinline thinline neck pickups are an exception ... there is barely enough wire to connect as it is ... any shorter and game over.
    Oh and I except swaps for pickups too.
  • guitars4youguitars4you Frets: 14304
    granted it was used, but I had a Seymour Duncan the other day to fit that had about a 4" cable left on it - Customer brought it in to me to fit to an LP copy - I can only assume it came from something like a 335 and the previous owner just 'chopped' it off at the pick-up end, saving him the hassle of taking out the wiring loom etc
    Even 1/8"? That's all you need to test-fit a pickup and cut the solder cleanly off again. I admit some people won't be quite that careful.
    That would definitely count as a used pickup at that point. It's a particular nuisance if it's a covered humbucker, since to change the cable properly you have to take the cover off.
  • impmannimpmann Frets: 12668
    Tbh, why buy USA pickups?
    We have the best pickup winders in the world here in the UK.
    Genuinely, if you can’t get the sound you are after from one of these guys, you won’t get it from anywhere else.
    I say that after 30 years of being down the rabbit hole of guitar pickup tinkering!
