Is this possible or am I imagining it? Origin 20
paulnb57paulnb57 Frets: 3055
Marshall Origin 20 combo, love it and came to accept that it doesn't have much drive on tap, I run it in middle power mode with the gain up to max and its pretty clean, however yesterday, the stars aligned and I was able to run it flat out at max gain, max power, loved it! Only for a couple of play thoughs of Pretty Vacant, so not long.....
When I reduced everything back to normal bedroom settings, at middle power, I seem to have a bit more dirt, (great!) is that even possible, or am I imagining it?
Has running it flat out changed something?
It's not much, but I'm convinced it's changed for the better.....
  • SassafrasSassafras Frets: 30301
    Temporary deafness?
  • ICBMICBM Frets: 72494
    You've started to break the speaker in. The initial part of it happens very fast, just thrashing it for five minutes will make a noticeable difference. A few hours will get it most of the way to the 'final' tone, and eventually the rate of change just slows down towards imperceptible. A more broken-in speaker will be more lively and you'll hear subtle harmonics more, which you will probably hear as a better overdriven sound.
  • paulnb57paulnb57 Frets: 3055
    edited January 2019
    @Sassafras ;;;What?! (I did wonder)
    @ICBM I considered that but had no idea it would happen so quickly and noticeably, thanks!
    I have no idea why some of this is bold/italic, iPad has mind of its own!...
    You've accidentally hit the B and I buttons in the bar above the text box, most likely .
    @ICBM yes, accidentally, but no matter what I do it will not unselect them!
    Bloody iPad!
    Bloody iPad!
    You have to select all the text you've typed first and then it will work. But yes, the iPad/iPhone editor on this forum software is a pain in the backside...
    edited January 2019
    ICBM said:
    Bloody iPad!
    I did, it didn't.....
  • welshboyowelshboyo Frets: 1816
    I bought a Bogner Atma which had been babied in 1 watt since new and it sounded a little anemic until I was able to give it full beans at a gig and the tone has definitely improved with the speaker being broken in - made a huge difference
