Do you use Major Scale MODES? Do you really understand them?
  • vizviz Frets: 10720
    edited March 2019
    Fascinating and great stuff again.
    I think you might have placed an artificial constraint in your framework that is then throwing up irreconcilable issues.
    Firstly, the tonic is not just the root note of the major scale, but of any scale. A piece in a minor key has a tonal centre and therefore a I-chord, or a tonic; it also has a V chord, a IV chord and all the other chords. Therefore the minor scale degrees are: tonic, supertonic, mediant, subdominant, dominant, submediant, subtonic (minor lacks the leading-tone) and tonic.
    Likewise Dorian and Mixolydian and the other diatonic modal scales also have a tonic, supertonic, mediant, subdominant, dominant, etc. Some of them lack a leading-tone, others lack a subdominant or a dominant, but in all cases they have a tonic. Bb Dorian’s tonic is Bb not Ab.
    Secondly, you say the scale is defined by its key signature, but this is not quite correct. The scale is defined by its key, because key-note and tonic are synonyms; the key signature is just the most convenient way a composer wishes to describe the palette of notes.
    These two facts unlock all the inconsistencies. Obviously everyone is familiar, having clarified the tonic note, with asking the question “is it major or minor?”. And then if minor the convention is to use the key sig for the relative major. if this were not the case, a piece in A minor would have a key signature of 3 sharps and have every note naturalised in the music! I guess if you were particularly perverse you could even have a key sig of Db major and spatter the music with accidentals.
    But with Dorian for example, the choice of using the relevant key sig as though it were Aeolian (ie the Aeolian’s relative Ionian) and sharpening all the 6th notes in the music, or using the key sig of Dorian’s diatonic Ionian key, is one for the composer. I prefer the former because I see Dorian as a type of minor scale not a mode of major; others prefer the latter.
    Then when we come to harmonic minor for example, there is no available key signature, because our key system is built around diatonic, so the key sig is as though Aeolian and the 7th note has to be sharpened in the music.
    Good banter.
  • Hi Viz,
    You are quite right to pull me up on "key signature".  I really meant simply "key".  Mistakenly adding "signature" means something else as you rightly point out.
    Now, on the tonality functions.  In my book I develop the following table to illustrate how I saw the 'tonic' note shifting and the consequence of that for the tonality functions within each mode.  One of my reviewers particularly thought that an interesting analysis of factors determining the different sounds of each node. What do you think?
  • OOPs.  The tables I referred to did not transfer to the post.  Not sure what went wrong there. Will try again later.
    Hi Viz,
    Sounds interesting - upload the table as a picture into Imgur or something and copy paste the direct image link.
  • stratman3142stratman3142 Frets: 2204
    You've got my interest.
    It's not a competition.
  • Hi Viz & Stratman - Not sure if I've done this right re: Imgur, but here goes:
    Page 1 - https://imgur.com/UgUxzSn
    Page 2 - https://imgur.com/rHPJm3I
    Notes -
    Where I use "Root Variant (RV)' (just my term) your term would be 'Mode'
    Page 1 Table 1  - read vertically and horizontally
    Page 1 Table 2  - I'm obviously referring to Myxolydian Mode ('C Variant) relative to Ionian Mode
    Page 2 Table - read mainly vertically upwards from root/tonic, but there is a horizontal relationship shown too
    Cheers,
    Richard
    edited March 2019
    Am I reading it correctly when I say you are thinking of modes in Relative terms in both diagrams (C ionian, D dorian, E phrygian efc), not in Absolute terms (C Ionian, C Dorian, C Phrygian ...)?
    In which case, yes the tonic note remains on C of course, even if the root of a chord may change (like in a ii-V-I, the D minor and G7 as chords have their roots on D and G, but the tonic is still C)
    But when you consider modal music, written in, say Dorian, the fact that Dorian is the 2nd mode of something is irrelevant. In fact, more relevant in that case is that Ionian is the 7th mode of Dorian!
    or am I talking cross purposes?
    btw if you select the direct link for your images they’ll show in the text of your post
  • Yes 'relatively' not 'absolutely'- those tables are simply trying to offer a perspective (beyond the 'conventional wisdom' interval differences explanation) as to why the modes sound different whilst playing the same notes from a different 'root'  note in the given major scale key.
    In 'absolute' terms (i.e. modes with the same 'root' note) of course mean a different (major scale) key in each case but, within that key, the same 'relative' tonal function differences apply.
    I think (or rather 'hope') that I make that distinction clear, or  clearer, in the section on modal relatives/equivalences and in the section on 'Method' where these principles are applied to the fretboard.
    edited March 2019
    I know I am the most uncouth contributor to this thread, and I have been following what is going on, but am I the only person who constructs scales and modes by ear to fit a particular chord progression? Cycling through 12 notes quickly makes it obvious which notes are in or out of a scale/mode. I'm getting a horrible feeling that I may be doing something wrong
    ( P.S. The perceived advantage when doing it this way, is that every scale/mode I construct always sounds brilliant with the chord progression).
    Art IS uncouth and your approach is spot on!
    Theory’s primary purpose isn’t to inspire (though it can help in the creative process), it explains how and why something works.
    I think we all do it your way :)
    edited March 2019
    I think either I’m being a bit slow here, or maybe I’m trying to find new insight in something I already know.
    Is this an example of what you are saying?:
    Take the key of C major.
    Play a piece like Happy Birthday, and on the first ‘you’, the chord moves from tonic to dominant (the V chord), which is G.
    Then, if you were to play the notes of that chord, as a scale, they would be GABCDEFG, which if taken out of context is a mixolydian scale - ie. it is like a major scale but has a flat 7.
    BUT (and is this your insight?) it’s not absolute  Mixolydian mode, because we’re still in C major, so the mental root of the piece still as to be C even though the temporary root of the chord is G?
    Therefore when ‘playing mixolydian mode on the dominant’ in the context of its relative major, that root note (the C) has a special melodic function within mixolydian?
    If so, I would not use the word mixolydian mode to describe what’s happening on that V chord; I would simply say “we’re in C and we’re playing over the V chord”.
    (This point is well described by the hypomodes concept where the home note is not defined by the top and bottom of the scale, but the middle. I chose Happy Birthday, because it actually spans dominant-to-dominant - the top and bottom notes are G, even though it’s in C. Nobody thinks Happy Birthday is in G Mixolydian. The Skye Boat song is another one).
    edited March 2019
    Yes I agree. Whatever, works for you. My approach is biased towards being very analytical. Others might prefer a more artistic, intuitive or empirical approach. But I think there's a bit of each in all of us
    It's an interesting discussion and touches on how individuals think about things and how they apply the knowledge.
    To add my own thoughts:
    I just treat scales/modes/arpeggios/hybrid scales etc as useful labels (or models) for sounds ('palettes' to steal a phrase from @viz). To me, the labels (or models) are akin to mathematical models and I found the following pertinent statement on Wikipedia.
    "A model may help to explain a system and to study the effects of different components, and to make predictions about behaviour."
    In this context the 'model' is the scale/mode/arpeggio etc, and the 'system' is the sound (or palette).
    Take the Dorian mode as just one example. I heard the sound of players like Peter Frampton and Carlos Santanna and, not only wanted to copy things note for note, but also to create musical phrases of my own with that type of sound. I found I could do this by adding notes (i.e. the 2 and 6) to a minor pentatonic scale (model) I was already familiar with.
    So now I've got a new extended model called the Dorian mode. It's like the model I had before (the minor pentatonic) but with a couple of additional notes. But it's not only a theoretical thing. I'm familiar with the sound of a minor pentatonic and now I can build on that familiarity and add some extra sounds to my vocabulary (theory and 'ear' working together).
    Then I discovered that playing over a 12 bar blues (such as Crossroads) I could use the major pentatonic and minor pentatonic, or I could think of it as the two scales layered on top of each other. You end up with a scale which happens to be the same as adding a major 3rd to the Dorian mode I already knew.
    So now I've got another sound (major 3rd) I can add to the Dorian mode. And I can also relate that to the major and minor pentatonic scales I'm already familiar with. Again it's not just a theoretical thing, it builds on and forms connections to sounds I'm already familiar with (theory and ear working together).
    But this thing I'm calling 'Dorian with an added major 3rd', which is useful for blues soloing, I could also think of it as Mixolydian with an added b3. Well it all makes sense in my mind at least
    So, through this process, the basic models are adaptable and extendable. And there are connections with previous and other knowledge (theory and 'ear' working together).
    It all sounds complicated when it's put into words, but words are clumsy tools for describing sound. I'm fairly confident Clapton wasn't thinking 'Dorian with an added major 3rd' when he played his 'Crossroads' solo. It's just a label I might choose to put on it to rationalise it in my own mind.
    I'm not saying my method is right. Different people might think of the same thing in different ways, but I don't view this as an real inconsistency. It's just a different viewpoint (perspective).
    Continuing with the Dorian mode as an example:
    Below are just a few ways of thinking about D Dorian:
    1) Like a C major scale, but starting on a D note.
    2) In terms of its intervals (1, 2, b3, 4, 5, 6, b7). Which is a bit like thinking of it as D major with a b3 and b7.
    3) D minor pentatonic with an added 2 and 6. My preferred way (although I'm aware of other ways).
    4) The relative major of D minor (i.e. F major) but using the Lydian form. This might seem somewhat convoluted but it was how I used to attempt to rationalise things. Probably because I knew major scales first and used to think of minor scales as similar patterns moved three frets up.
    5) And on and on ....Feel free to add your own thought process.
    I feel that the important thing is that everyone ends up at the same destination (i.e with the same notes) when they say 'D Dorian'. They might get there by a different thought process, and that's good and shows individuality. I'm not convinced there's an absolute right or wrong way. There's only a problem (a real inconsistency) if the thought process leads to a different end result.
    That's just the Dorian mode. Don't get me started on the other modes, or the modes of the minor scales
    Dorian is a mode of the minor scale ;)
    I 100% like your empirical approach. Wish I could claim palette as my own but I’m sure I read it somewhere else!
    viz said:
    ...I 100% like your empirical approach...
    And here's me thinking my approach was mainly 'analytical' :)
    Well analytical through discovery maybe :)
    edited March 2019
    I know how the modes work, but I am trying to get away from the theoretical aspect. I want to hear what sounds good, instead of thinking about it.
    I've taken art classes and we learned about colour theory, but the real action was on the palette where we mixed the paint. My approach to music is influenced by painting, and also elements of computer science! I always sketch ideas, and then use stepwise refinement to flesh them out. It's not such a strange idea, as when we were learning to draw, we would practice by focusing on one area at a time, e.g. the eyes, nose, mouth, ears, hair, and then ultimately combine them all together.
    I read the rest of your piece, it's very interesting and I agree with your thought process,  but you covered quite a bit of ground there for me to comment on everything. You got a Wiz though
  • Hi Viz, Stratman, Freebird and all other contributors.
    I don't disagree with any of your contributions or perspectives and I don't think that anything in my book does either.  It just looks at them perhaps a bit differently and maybe even naively or too simplistically.  The book was the result of simply writing down my own thought  processes in some sort of logical (to me) order starting with a premise*, then a set of principles^ and then attempting to reach conclusions~ based on those principles (see the summary of how I organised my thoughts below).
    The premise^, the principles^ and the conclusions~ are solely how I see them based on the way my brain works when attempting to learn new stuff in circumstances where there are no clear sources of knowledge that are sufficient and authoritative enough to be relied upon.   You only have to read posts on forums like this and the huge range of written literature to see that there is so much 'matter of opinion' stuff on modes.  Perhaps in the end that is exactly right, they are a 'matter of opinion'.   I might reach that conclusion myself in the end but for the moment I like to think that at least I can operate (at my simplistic level) with a logic and a structure that I can work with and see where it takes me.
    I have found this forum and contributors like yourselves encouragingly willing to participate in an exchange of views and ideas.  Other forums vary.  Some are like this one.  Others seem to have self appointed  'resident experts' who are quick to be dismissive of someone like me who openly admits to being an 'amateur' on the subject. They don't bother me personally but. unfortunately, they may well intimidate others from participating in fear of being put down.
    *Premise:
    The MAJOR SCALE (and its 'relative' Minor) is the 'Parent' of all other scales (not meant in any 'authority/superiority' sense of parent, purely in the sense that all other scales are derived from it and that their scale notes - natural, sharp, flat - are defined relative to it)
    OTHER SCALES  are 'alternative' tonal entities in their own right but are still notated relative to the Major Scale.
    ^Principles:
    Modes are 'intrinsic' to the Major Scale (they are not OTHER SCALES).
    Modes have a uniqueness but also a commonality.
    Modes can be Major or Minor (Locrian as  a special case).
    Modes (6 of them) sound different from the parent and from each  other.
    Modes are identifiable and available across the whole guitar fretboard.
    to reach ~Conclusions on :
    What are Modes?
    How do Modes relate to  the Major Scale and each other?
    What are their similarities and differences(uniqueness)?
    Why do they sound different?
    How can they be used in a Melodic context?
    How can they be used in a Harmonic context?
    Where can they be found on the guitar fretboard?
    How can 'relative'  and 'absolute' modal patterns be applied to the guitar fretboard?
    Best Regards,
    Richard
    edited March 2019
    ...OTHER SCALES  are 'alternative' tonal entities in their own right but are still notated relative to the Major Scale.
    ^Principles:
    Modes are 'intrinsic' to the Major Scale (they are not OTHER SCALES)...
    The above is an area that's interesting to discuss. It relates to a discussion on another recent thread.
    Suppose you're playing a song like I Wish by Stevie Wonder, which is essentially Dorian. For the sake of argument, and to keep things simple, lets assume it's in D Dorian?
    By your argument (i.e. relative to the major scale) would you set the key signature without any sharps or flats, which equates to C (or its relative minor, which is A minor).
    But if anyone were to ask what key it was in, I think most would say it's in D minor, which would be notated with a key signature that has one flat, then accidentals would be included to convert each Bb to a B natural.
    Btw. I was once given a chart for Funky Music that had a key signature with three sharps. That might indicate a key of A, but in fact it was in E (Mixolydian). So the person that generated the chart was  saving on the number of accidentals that needed to be included to convert every D# to a D. But I found it confusing and would have preferred 4 sharps in the key signature to indicate that it was in E
    edited March 2019
    Stratman your example of I Wish is a classic use case. Both options are ok, but I also prefer your method. It’s more practical, and the reason is that Major and Minor are SOOO much more prevalent than the other 4 scales that they serve as the two foundations, off which the modal pieces deviate.
    Maybe that will change in time. Originally there were 8 modes (4 modes and 4 hypomodes); Ionian wasn’t even amongst them.
    Then Ionian and Aeolian became prevalent. Ionian rose as the standard due to the popularity and consonance of hypolydian.
    So ClearyRich, I’m just not sure I agree your premise about everything being based off Major. In my mind, Ionian and Aeolian take equal place like king and queen on the thrones of the musical kingdom, and all other modes derive from them. For convenience’s sake, Ionian is chosen as the one to base the others off in construction, but not in musical sound. When we look at a piece in A minor with no sharps or flats, we don’t keep dragging the concept of C major into it once we’ve worked out it’s in A minor - C major is irrelevant.
               Home note
            major or minor?
              _____|_____
         Ionian         Aeolian ——— Harm / Mel?
        ___|___       ___|___
    (adding chromatic interest)
      Lyd?   Mix?  Dor?   Phr?
    But that may change. Nowadays in popular music Mixolydian and Dorian are more common, and in jazz, melodic minor is prevalent. Who knows, maybe in time, we will glance at a key sig of zero sharps and flats and immediately assume it’s in D Dorian.
  • So ClearyRich, I’m just not sure I agree your premise about everything being based off Major. In my mind, Ionian and Aeolian take equal place like king and queen on the thrones of the musical kingdom, and all other modes derive from them. For convenience’s sake, Ionian is chosen as the one to base the others off in construction, but not in musical sound. When we look at a piece in A minor with no sharps or flats, we don’t keep dragging the concept of C major into it once we’ve worked out it’s in A minor - C major is irrelevant.
    I agree with you on that totally,  When I finally get a copy of the book to you you will see that I interpret the Ionian as the head of the major modes and Aeolian for the minor modes (Locrian is a bit of an outsider).
