*TRADED* Gibson Memphis ES390 Hollowbody 2015 *£1200* price drop
skaguitarskaguitar Frets: 971
edited July 2019 in Guitars £
I've recently bought a guitar that is a game changer for me so going to be selling a few bits and pieces and this is one that has to go as I don't believe in keeping guitars as wall art.
A lovely cherry Gibson Memphis ES390 from 2015
NEW FEATURES FOR 2015 MEMPHIS GUITARS:
•                   F-Hole emblem engraved truss rod cover: The iconic symbol of theGibson ES line is now the hallmark of Gibson Memphis.
•                   Kluson single ring tulip button tuners: Authentic vintage stylemachineheads
•                   Redesigned neck dimensions: Added thickness to Pegheadtransition provides greater strength and stability.
•                   Historic truss rod: Superior Adjustability due to the Tefloncoating, larger diameter rod, original brass anchor and larger washer.
•                   Bone nut: Bone for smooth tuning and excellent durability.
•                   Rolled neck binding: Binding is rounded off to comfortably fitthe contours of the player's hand.
•                   Block inlay fretboard: Block fingerboard inlays are synonymous withthe 1960's ES-335.
•                   Low profile frets: Lower fret height provides smooth playabilityand accurate intonation.
•                   MHS P-90 Pickups: Recreating the glories of vintage single coils
•                   Capacitor changes: Less treble cut than previous capacitorresults in a tone with a harmonically rich, singing quality.
•                   Trapeze tailpiece: Die cast alloy with Nickel plating
GIBSON 2015 CUSTOM SHOP LIMITED ES-390WITH NICKEL P-90S
•                   Body: 3-Ply Maple, Poplar, Maple laminate, fully hollow body
•                   Neck: Mahogany
•                   Truss Rod: Historic
•                   Profile: Traditional 'C'
•                   Thickness at Fret 1: 21.59 mm / .850"
•                   Thickness at Fret 12: 24.13 mm / .950"
•                   Nut: Bone
•                   Fingerboard: Rosewood
•                   Radius: 30.48 cm / 12 "
•                   Frets: 22
•                   Nut/End of Board width: 1.675" @ nut, 2.23" @ end ofboard
•                   Scale: 24.75"
•                   Fingerboard Inlays: Pearloid Blocks
•                   Finish: Hi Gloss Nitrocellulose Lacquer
•                   Neck Pickup: MHS P-90, Alnico III rod magnets, 8.53kO
•                   Bridge Pickup: MHS P-90 reverse polarity, Alnico II rod magnets,8.54kO
•                   Tonal & Resonant Advancements: Recreating the glories ofvintage single coils
•                   Volume Pots: CTS 500K Linear
•                   Tone Pots: CTS 500K Audio
•                   Capacitors: Orange Drop .022 mF (Lead), Orange Drop .015 mF(Rhythm)
•                   Tuning Keys: Kluson Double Ring Tulip Button
•                   Bridge: Tone Pro AVR-2
•                   Tailpiece: Trapeze
•                   Case: Hard Shell, Tan
•                   Other: Gibson Memphis Certificate Of Authenticity
looking for £1200 and collection only from Bedfordshire
pictures
https://imgur.com/ZfEaiz2
https://imgur.com/AMKOavT
https://imgur.com/q6Q0g1w
https://imgur.com/1181Kaj
https://imgur.com/33lf5Zl
https://imgur.com/jGw7YyM
https://imgur.com/CvvenJ4
  • “To play a wrong note is insignificant; to play without passion is inexcusable.”
«13
  • equalsqlequalsql Frets: 6140
  • skaguitarskaguitar Frets: 971
    thanks @equalsql ; :)
  • pruddprudd Frets: 662
    have a WOW
    Midweek bump
    weekend bump
    up
    weekend is here bump
  • chris78chris78 Frets: 9329
    I was after one of these when I got an Es-330 last year. Lovely guitar and much more manageable than a full sized one
    Thanks...they are really good guitars...especially if you're vertically challenged like me and full size 330's and 335's look ridiculous on you ..!
    bump
    weekend bump
    up...
    saturday bump
    Tough crowd
    Tough crowd
    Yep ...I think it’s priced right too... :)
    bumped...
    ttt
    price drop to £1500...
    bump
