Carl Martin Plexitone
Picked up in a trade recently but not really my thing.
Good condition.
£115.00 including postage (ppg)
Burkey Flatliner Power supply. £125.00 posted PPG
Super versatile power supply offering lots of options.
Specifications | |
9V DC | 5 Outputs 9 Volt DC, 200 mA, short-circuit protected with a current-limitation on 200 mA |
12V DC | 1 Output 12 Volt DC, 200 mA, short-circuit protected with a current-limitation on 200 mA |
3-9V DC | 1 Output variable ca. 3-9 Volt ; V = voltage, R = resistance ( 0…20 Ohm) |
3-12V DC | 1 Output variable ca. 3-12 Volt ; V = voltage, R = resistance ( 0…20 Ohm) |
9/12V AC | 1 Output 9 or 12VAC*, capacity 1000 mA This output is protected with a 1AT fuse (on the rear panel) |
Polarity | All outputs are centre negative |
Fuses | 1AT:1A-fuse (9VAC output) |
Mains | 230VAC 50/60Hz for European power. Configurable for 120VAC/60hz for US power |
Capacity | 33 Watts max |
Weight | 1960 gr |
Dimensions | (LDH)233x110x72 Included also are a few cables ,a voltage doubler and reverse polarity cable. This unit is used but in full working order.. Am struggling with Imgur with pics at the mo so will try again later. |
If so, what's the total cost? (Kingsley Bard, shipping, paypal)
Thank you for your reply.
Jesse
