Latency was 'ok but not great'- I forget exactly what, I suspect around 8-10ms.
There is a way you can verify.
1. Use an IO plugin on a hardware insert and 'ping' it which will give you latency in samples.
2. Set up a send to an output that is recorded back in on an input and then manually drag by samples so they line back up, counting the sample displacement.
It is crazy that in Pro Tools option 2 is the only way to work out hardware latency. In 2019.
