SOLD- Zilla 1x12 cab in purple tolex Celstion G12M 25w 16ohm - £200
TheGASManTheGASMan Frets: 385
edited June 2019 in Amps £
Hi All
I no longer need this as I am using a helix through a power cab plus
As title says this is a zilla 1x12 cab with Celestion G12M 25w 16 ohm
Also as you can see the rear panels are removable to give some flexibility with sound
Dimensions 53cm wide, 54cm high, 30cm deep
Pick up only from North Kent near M25 J4
Looking for £200
Thanks
Andrew
