Mini / stick pc ? Any good?
sev112sev112 Frets: 2771
im looking for the cheapest pc I can find, used or new, to do very little except surf internet and run a couple of pieces of simple software which I can’t run on iOS (I use ipad for all other computing)
thoughts / suggestions?
am toying with getting a 10 year old Sony laptop up and running vista again to see if it will fit the bill but wondered whether I’d get extra value from say a memory stuck pc, as it is capable of more
  • SnagsSnags Frets: 5387
    Probably depends on the "couple of pieces of simple software".
    Would strongly suggest not using Vista under any circumstances, though. W7 or W10, nothing in between.
  • notanonnotanon Frets: 610
    You will be pushed to find anything that beats
    https://en.m.wikipedia.org/wiki/CrunchBang_Linux
    with respect to resources. It depends on what software you intend to run.
  • darthed1981darthed1981 Frets: 11793
    Worth bearing in mind W7 loses it's security updates early next year.
    So a W10 device is the way to go at this point.
  • Axe_meisterAxe_meister Frets: 4647
    An Atomic Pi if you can find one in this country.
    $35 for a 4 core Atom processor (x86) and can run Windows
  • guitartangoguitartango Frets: 1027
    edited May 2019
     Windows
    I doubt you can run the latest Window's 10 on this device, you would run out of disc space within weeks
    “Ken sent me.”
  • MikeBMikeB Frets: 176
    I'd try a Linux distros on the old laptop. Plenty to choose and depending on the little bits of software you need, would do what you want.
  • digitalscreamdigitalscream Frets: 26639
    The problem with those stick PCs isn't the CPU power (although it's pretty lacking, and they usually feel about the same speed as a budget tablet). It's the storage - not only isn't there a lot of it, it's slow. eMMC just isn't a high-speed medium.
    I just picked up a barebone Gigabyte Brix PC with an i5 CPU from eBay for £140. £20 on an m.2 128GB SSD and about the same on 8GB low-voltage DDR3, and it's steaming along. Small, quiet, cheap...what's not to love?
    You have to hunt around a bit to get the good deals, but if you're not bothered about a low-powered CPU then you can pick up the quad-core Celeron ones for £80-90.
    For what it's worth, mine's getting Ubuntu, Reaper and Helix Native on it - I'm building a cheap backup for my Helix :)
    <space for hire>
