I just don't use it and it's getting a kicking in the loft - maybe a music charity is the solution.
I've now got another Helix LT as back up. But I'll always keep my GT6 because I chose it for my company 25 year award when they first came out (which shows how old I am).
Nil Satis Nisi Optimum
I can't see it being worth a lot now - there's a GT-10 in the shop I used to work for at only £149, I imagine the 8 may be worth even less - but if it sounds good then there's no real reason to sell it anyway.
If you are definitely going to sell it, I may be interested...
1. Rugged construction that's reliable and won't let me down
2. A robust long heavy duty power supply with a standard 3 pin plug and no wall wart.
3. Real knobs and dials for instant tweaking on stage
4. Instant no lag patch changing
5. Patch naming with a clear lit screen I can easily see on a darkened stage
6. Built in expression pedal for volume/gain and at least one control switch to kick in a boost.
7. Accurate fast access tuner in any mode
8. Good tones with a valve feel and dynamics that respond well to volume and tone roll off
9. Simple, fast access to amp, cab and fx models without complex menus and no DSP grey outs
10. Edit program to create, change order, and import gig sets
Modern units are great for home and studio playing and you can have a lot of fun and hear all different nuances of amp, cab and fx models. But here's the thing; at gigging volumes in a band mix, all those detailed nuances largely go out the window.
Which is why I'm still gigging with really old tech, my Vox Tonelab SE and LE. Ahead of their time in 2004 and 2007 respectively, by today's standards these are from the ark. They have no fx loop, no moveable fx chain to speak of, no built in usb audio interface, no upgradeabilty, limited amp, cab and fx models and options, and no IR capability.
But they tick all my must haves, the valvereactor design still sounds great, and to date I've not found anything that does better the job I need an MFX to do on stage. The SE even has 2 expression pedals and A/B switching in each patch, that let's you have different cab and amp. Models in A and B.
So just because something is old tech and not 'in' or 'fashionable' doesn't mean it's automatically junk. If it suits your needs and sounds good, then it's not junk.
Also, old gear can be picked up cheap. I wanted a TLLE as a backup and these can easily be had for under £100. In fact, I found one on Ebay that I won for £55 inc postage last week. The seller confirmed that it all worked perfectly and has the original Vox PSU too. Should get it tomorrow.
Some years back I heard a fabulous one man show at my cousins anniversary party. His guitar, a stock Les Paul Standard ( not Custom Shop or anything) was going through an ancient Zoom mfx that you probably couldn't give away and made my Tonelabs look state of the art, that just went through the PA. He sounded incredible! And it really was a wake up call that all the latest most expensive gear in the world is no substitute for sheer talent.
The FX are Boss copies of their own pedals. I’m not enamoured by the COSM amp modelling, but you can run it in 4CM with your favourite amplifier.
I really don't get the "oh no! the new thing is out, my thing is crap now" approach. My Helix will still sound as good as it does now on the day Helix 2 comes out.
