Ok, disclaimer first: There is no right or wrong way of building pedals, do what works for you and that’s the right way for you. Right that out of the way…
Solder
If you’re not planning to sell your pedals commercially, use leaded solder. Unleaded is an utter pain in the arse and is horrible stuff. You WILL need a 40W iron just to melt the stuff. It’s horrid. If you are planning to sell, bite the bullet and get used to it, because legally, you’re stuck with it (indeed, you cannot use non-ROHS items in your pedals like LDRs or Vactrols also).
However, if you’re doing it for you, there’s nothing stopping you buying and using these things perfectly legally. Bizarre but true. So, the solder I use is this: http://www.rapidonline.com/tools-equipment/autosol-bit-saving-solder-flux-ra-22swg-500g-85-6242
Iron
For an iron I have a couple. A triggers broom 18W Antex with it’s standard bit. You can get all the parts (elements, bits, etc) from your favourite electronics retailer. I think the only original part on mine is the actual handle. I also have a 25W Antex with a chisel bit for doing guitar electronics. They take a bit more poke.
Get a stand for it. Ideally one with a sponge or the mesh style bit cleaning basin in it. Keeping your tip clean is key. I always wipe before and after use. Works also for your knob.
Basic Tools
Good small side cutters. Not the stuff you’ve got from your Halfords generic car set. You don’t have to go to town. I use these: http://cpc.farnell.com/pro-s-kit/pa-101/plier-micro-cutting-130mm/dp/TL08717
When they get blunt, bin 'em and get another set.
Small needle nosed pliers. Same applies as above. Small=good.
Wire strippers. Go with the type you’re comfortable with. I use manual ones. I’m just used to them.
Tweezers. Good for routing wires through those hard to get places.
A selection of small screwdrivers.
A selection of small sockets and a socket driver. I actually do use a Halfords Professional set of those. Possibly the most useful tools I’ve ever bought. This one, I’ve had it years: http://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-36-piece-socket-set-1-4
Helping hands. Even a pikey horrible set (which I have, I really need to replace those) is better than none. http://www.rapidonline.com/FFSearchResults.aspx?query=helping hands&filterSearchScope=3
Get a half decent multi-meter.
Drilling boxes
Get a drill press, it’ll save you a lot of time and ruined boxes, trust me on this, and a step drill bit (1mm increments). Something like this: http://www.rapidonline.com/Tools-Equipment/Step-Drill-4-12mm-89-4432?sourceRefKey=kduvA4cGx&filterSearchScope=3
Measure, mark, twat with a centre punch, pilot with 3mm bit, take out to size with the stepper.
Finishing boxes
How you do this depends a lot on what type of finish you want to achieve. Rattle cans are a pain in the arse in terms of mess, temperature (try spraying in the garage in winter…), and the fact that painted finishes chip and ding easily.
Powder coating is the best way to get a coloured finish that’s tough, but if you want to do that yourself that’s a compressor, kit and oven job. You can buy in Hammond enclosures pre-coated (the way I do it). Quality of finish is variable and it might want some wet flatting…
Waterslides/decals. I use the latter. Other options are paint, paint pens, etching, screen printing, acid/laser etching, yadda. For decals I get clear transparent adhesive decals from Crafty Computer Paper. If you get it on offer and get enough of it to get free delivery, it works out about a pound a sheet. But you will have to get about £35 worth to get it for that. Obviously don’t waste it. There’s a tutorial on my site anyhow for doing those.
Other finishes… IMO most suited to one offs and DIY is an epoxy finish called Envirotex Lite (get it from the states via Amazon 16oz set). It’s primarily designed for coating bar tops and it’s insanely tough. Perfect for jack booted excitable musicians It takes a bit of getting your head around using it. But it’s clean and easy and can be done indoors. Better still it’s removable, with a bit of effort. I’ve not found anything better for this sort of thing.
Advice
Finally some advice for those thinking about starting this insanely addictive hobby.
Start with a BYOC kit (Vibe-o-tronic sell them here). Do a couple to get your eye in, then get off them as soon as possible as all you’re doing is painting by numbers and you won’t learn anything more like that. They will however get you into some good habits.
Make a audio probe (google it, it’s simple) and go through something you’ve built whilst looking at a schematic. This WILL start to teach you stuff. a) how to read schematics, and b) how to fault find. Fault finding generally works thus: First you make sure you have all the right voltages where you expect them (multi-meter). Then you audio probe through the signal path of the circuit until it stops. Your problem is around there.
Do some vero. You can build all sorts on vero. It’s DIY at it’s most DIY. Great for prototyping when you come up with your own ideas.
Build a stash of parts.
There’s a set of DIY links on my site that contains all the main players for parts (UK centric), PCBs, some vero ninjas and forums. Get yourself on either BYOC or Madbean. They’re both really helpful newbie friendly places. It’s a community and the more you take part, the more you’ll get out of it.
Which order makes most sense?
