I've stuggled before with solderless cables (Bullet slugs) which put me off using them but I think I may need them for what I intend to do hence I beseach the wisdom of you fine gentlemen.
I'm thinking an In/Out pedalboard patch box might help me here as well and I'm open to shifting the arrangement. (Although this is the most comfortable layout I can get to my knowledge.
I had looked at a custom input/output version of a BoiceBox but I'm not sure if that would help (it'd sure be expensive!)
Cheers as always guys!
The LS-2 is configured to allow me to turn on one guitar while turning off the other which I need to do live. (Saves using the volume knob on the electric when quick changes are needed.)
Can anyone make me a 6" insert cable with all right angled jacks?
If it does have two truly independent signal paths then it would be possible to wire it up to work both in the loop of the Aura and in the amp's loop at the same time, yes. If not then it won't be.
You may still run into problems with ground loops or other issues with mixing both systems together. It really is better just to keep them separate if at all possible.
