Just finished my newest 12-string tele
Winny_PoohWinny_Pooh Frets: 7802
edited January 2016 in Guitar
I've had a previous DIY conversion based on those of telesavant on TDPRI which worked ok although the tuners were crude open back types.
http://i.imgur.com/Leyaajf.jpg
I went one step further and put on a body from a custom build w Lollars. (http://brianfanner.wix.com/fannerguitars#!guitars/c4l2) Eventually though the truss rod on the squier neck started slipping which meant I would have to tighten the hell out of it every time I picked it up to play. And it would slip back the same amount overnight.
So it sat for a near on two years. After some swapping I had a wide neck sitting spare and was missing playing the twelve so I placed a custom order of M6 tuners (6 in line reverse) with thomann which arrived after a couple weeks. After drilling over the new year weekend I finished the new nut last night and did some setup. With the correct strings (Unison Gs!) it rings and sounds great :)
http://i.imgur.com/7FaBIZl.jpg
Here are some progress pics: (hiding some minor bodges: should have used a spacing template) I had to plug and redrill the original 8mm holes so that the new tuners would be closer to the headstock edge and offset to allow for clearance of the tuning pegs.
http://i.imgur.com/F9yyzJR.jpg
http://i.imgur.com/aZUBLWU.jpg
This part had to be done by hand http://i.imgur.com/J68yGJ2.jpg
And a week later, done! http://i.imgur.com/SPwUsHX.jpg
http://i.imgur.com/aebkZdH.jpg
http://i.imgur.com/orIsJR6.jpg
  • WezVWezV Frets: 16782
    That's very clever, but how the hell do you restring it ;)
  • Winny_PoohWinny_Pooh Frets: 7802
    edited January 2016
    You push in the string as hard as you can, twist and turn and somehow it works! Like babymaking
  • GassageGassage Frets: 30947
    edited January 2016
    Top effort.
    And if you don't like it you can send it to M D Phillips who'll convet it back to a 6 string for people with sausage fingers wiuth an improved Heath Robinson pick up
  • DeadmanDeadman Frets: 3927
    I love that.
  • SassafrasSassafras Frets: 30317
    Ingenious.
  • axisusaxisus Frets: 28341
    Fascinating!
  • Love it.
    I have 12 string GAS again now :-(
