My lad is coming up to 15 and has expressed a strong interest in photography. In particular of cars, and of people riding their skateboards, BMXs and scooters. Although he also likes landscape photography and has quite an artistic flair.
We'd like to get him something that will get him started and that he could build on - either by adding more lenses etc, or by keeping it as part of a kit so that he can carry different cameras for different situations.
Let's say we're looking at £150, would that get us anything worthwhile or do we need to come up a bit?
Frankly, that's more than enough to learn on - wex photographic has some for about £150.
http://www.wexphotographic.com/buy-used-nikon-d5100-digital-slr-camera-body/p1622830
It's nice and small, higher end ones are bigger for better ergonomics but... Big.
http://www.wexphotographic.com/buy-used-nikon-18-70mm-f3-5-4-5-g-af-s-dx-lens/p1622906
That's a good lens, probably better for action than the newer, but sharper, 18-55 vr lenses. No vibration reduction but it lets in about a stop more light at the long end so faster shutter speeds for freezing action. It also goes to 70mm instead of 55, has a metal mount and is pretty good. I still have mine, and I still like it! Focuses very close too, so decent for near-macro.
Of course, canon will have equivalents, and are probably more common cameras.
As already stated Nikon and Canon are a good place to start for great kit which can added to as time goes by. Being into action sports you should also check out the video spec on the cameras you are looking at as I'm sure it will give your lad another creative angle.
Not sure why s76fitz is seemingly spamming the thread with stuff from a USA retailer ?
anyway, hope you get your lad what he needs . Best of luck.
highest fps, af speed(although if a fisheye is on the cards at a later date that won't be an issue) and buffer you can afford, if you could stretch to a Canon D60/Nikon d7000 I reckon that would be a decent start, it would mean an increase in budget though.
Get your lad lad to join the talkphotography forum. There's masses of great info on there and plenty of people willing to help out beginners.
Thanks for the advice all, will have to do some research and try to get something usable for the small budget we have.
Without a lens the body is useless, right? So what's the essential starting option?
And, I hear about some cameras needing special, more expensive, lenses due to motors or lack thereof. Is that across both brands, and all models?
Are there lenses made by other manufacturers that are compatible? He's quite keen on a fish eye lens for his scooter action shots.
A fish eye lens is going to be relatively expensive, whatever the make, but as mentioned there are other manufacturers that make them to fit. Sigma and Tamron are decent quality but cost a lot less than a pukka manufacturer's lens.
There's not much difference between the main brands in terms of quality tbh. Best thing to to do is to go to a camera shop and have a play with the various makes of body. Some feel better than others in the hand or your lad might prefer the control layout of one make etc. Then you can go from there. I would definitely go for s/h though: you'll get far more for your money and photographers tend to take care of their gear, so you rarely get a dud.
