SO I need to move the brackets on the door for an integrated washing machine down by an inch or so. However the bracks are attached by inch and a hlf diameter metal plugs whihc are recessed into the door bout a cm deep or so.
Last time i tried doing something like this i used a dremel to try to rout a sutable hole but what i found was that i nearly set the door on fire rather than actually manage to cut anything, I basically kind of burnt out a roughly correct shaped hole in the end.
I assume im doing something dreadfully wrong, like using the wrong bit or something like that so could anyone give me some dremelling pointers
ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
but they wouldn't fit in your Dremel(!) (& a bit dodgy to use without a drill press).
Chipboard (I assume) is tough on bits, and they need to be sharp, so a carbide bit would be best IMHO.
I don't see anything wrong with trying to rout it out with a Dremel, but use a template to get the shape accurate and take it slowly to avoid burning (cut depth and feed rate, not motor speed)
Instagram
http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=9901
with the Dremel in some sort of router base (do they come with one?) to control the depth and some sort of template to control the outline.
(The drill press for the 35mm bits is to keep the hole square and avoid the drill jamming if you wobble off-line. I've got away with using Forstner bits in an electric drill before now, though - it's probably the way I'd do it. Just make sure the centre point doesn't break through!).
This has all the makings of an Emp/Chilli procrastination project.
