There's also the question of whether it needs a ground lift switch...
You will need the option of ground lift and phase with two amps, to be sure it won't cause trouble - although sometimes it will be fine without. Amp and DI, probably not necessary since any decent DI box will have ground lift, some have phase, and most desks also have phase. Parallel FX chains - depends.
Is your sum to mono active or passive? If it's passive you can probably use it backwards as a splitter. It's likely to be transformer-based and they work in either direction. If it's active, you can't.
Although, you can still use it to fix phase or ground-loop issues if you simply use it in *one* of the signal paths, after a simple splitter like a stereo/dual-output pedal.
So for one amp, use the sum to mono box as normal between the pedal and whichever amp you're using. For two amps, use it as above in the event of phase/ground problems - if you don't get any, you don't need to. That should cover all the options I think, no need for any extra kit.
I just wondered why some Sum to Mono boxes don't have the phase or ground lift switches included. I thought it would be quite standard for the possible eventuality
